Sold
1977 Economy Power King 1614 (mower, snowblower) - $1475
1 reply to this topic
#1 zuren OFFLINE
zuren
  • 243 Thanks
  • 233 posts
Posted April 30, 2021 - 03:45 PM
1977 Economy Power King garden tractor
Model 1614
S/N: 40796
Located in Chelsea, MI (just north of I-94)
Details/specs can be found here:  http://www.tractorda...-king-1614.html
Included attachments:
- 48” mid-mount mower
- Haban 42” snowblower (single stage; untested but everything spins)
Also included:
- Some extra parts
- A list of items that I have found needing attention
- Any paperwork and repair write-ups that I have found relevant to the tractor
I picked this tractor up as a project but have decided I do not have the time to move forward; too many other projects and young kids to look after.  I have replaced the following parts:
- PTO clutch
- Steering drag link (repaired)
- Voltage regulator
- Assorted hardware
- Battery
- Tubes in front tires
- Rear tires (left rear has a slow leak)
- Engine oil changed
- Transmission fluid changed (50/50 gear oil and STP Oil Treatment)
- Rear diff. fluid changed, new gasket
- Mower deck spindles greased and blades sharpened (ready to mow)
Starts and runs great.  This tractor is perfectly functional as-is, or would be a good project for someone who has the time and space to work on it to get it back to a “clean” factory state.  The previous owner modified the dash and transmission tunnel.  He also switched it to push-button start.  Rear transmission has trouble shifting but will shift (common issue - I’m including repair instructions).  Play in drivetrain may be due to worn axle shafts (relatively easy to repair/replace if you are handy).  The snowblower needs a replacement cable for pivoting the chute.  I will include a list of known parts sources to help get you started.  I have included video links of the actual tractor for sale.
Asking $1475 OBO.  Offered As-Is.
Edited by zuren, April 30, 2021 - 06:41 PM.
  • jcp7hp said thank you
#2 zuren OFFLINE
zuren
  • 243 Thanks
  • 233 posts
Posted May 04, 2021 - 10:27 AM
Tractor is SOLD.
Also tagged with one or more of these keywords: Sold
