* * * * * 1 votes
Kohler K582- Oil past the rings when sitting?
kohler rings oil k582 k532
4 replies to this topic
#1 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 3912 Thanks
  • 2078 posts
Posted January 12, 2021 - 10:59 AM
I have the heads off of my Kohler K582, and I've noticed oil seeping past the rings on both cylinders when it sits for an extended period of time(24 hrs).  It leaks enough that sometimes it will leak onto the floor.  Is this normal or should I be worried about problems with my rings?  Is this a problems with a lot of horizontally opposed engine?
The oil has been drained.
  • jcp7hp said thank you
#2 jcp7hp ONLINE
jcp7hp
    ( ಠ ͜ʖಠ)
  • 1163 Thanks
  • 584 posts
Posted January 12, 2021 - 11:09 AM
On my craftsman with the 18hp opposed twin briggs, mine would do the same. I think your right about it being something with the opposed twins. But idk much...
  • Mark 149 J. said thank you
#3 Bud W ONLINE
Bud W
    old member
  • 511 Thanks
  • 401 posts
Posted January 12, 2021 - 02:47 PM
It holds 3 quarts + 1 pint with the filter but I don't think that is enough to be above where the cylinders are.
  • Mark 149 J. and jcp7hp have said thanks
#4 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 3912 Thanks
  • 2078 posts
Posted January 12, 2021 - 03:06 PM
I don't think so as well.  I did drain the pan but the oil pump could still be squirting oil into the cylinder walls when I turn it over by hand.  I just don't know if the oil normally gets past the ring so easily.
#5 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 3912 Thanks
  • 2078 posts
Posted January 13, 2021 - 07:13 PM
I went out today and I didn't see much oil at the bottom of the cylinders.  I think the oil pump is now empty so maybe that's why I didn't see any oil.
Also tagged with one or more of these keywords: kohler, rings, oil, k582, k532
