MW hydro filter
4 replies to this topic
#1 bbstacker461 OFFLINE
bbstacker461
  • 2 Thanks
  • 4 posts
Posted January 11, 2021 - 11:15 AM
Hello,
Does anyone have a current P/N for a Filter for a 16 hp. MW Hydro.    I know it runs ATF but I cant find the correct filter.   The manuals P/N don't cross reference.    Im just using a oil filter for now.
Thanks
Murray
#2 GWest OFFLINE
GWest
  • 702 Thanks
  • 649 posts
Posted January 12, 2021 - 04:04 AM
What filter is on it now?
Garry
#3 bbstacker461 OFFLINE
bbstacker461
  • 2 Thanks
  • 4 posts
Posted January 12, 2021 - 06:46 PM
Hi
I am using a Napa  1068 oil filter
Murray
#4 GWest OFFLINE
GWest
  • 702 Thanks
  • 649 posts
Posted January 12, 2021 - 07:11 PM
A Napa 1410 is often used for a transmission filter. It does not have a by-pass valve.
See if this link works because I can't copy the info.
https://www.wixfilte...=1068|1410&o=me
Garry
Yes it works. Wix makes Napa filters.
Edited by GWest, January 12, 2021 - 07:13 PM.
  • KennyP, 29 Chev and bbstacker461 have said thanks
#5 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 21177 Thanks
  • 7085 posts
Posted January 12, 2021 - 07:48 PM
Attached is a pdf of the parts listing from the 1975 Gilson Parts list for the model 33186A which appears to be the model number you have on your Montgomery Wards tractor.
The filter (item S) shows as Gilson part # 14241 in the parts list.
here is a link that shows equivalents to the Gilson 14241
https://www.oilfilte.../GILSON/14241
You can also check with the Fram filter web site which cross references the Gilson part number to their part number PH43
https://www.fram.com/parts-search/
While the Wix 51068 (Napa 1068) is commonly used for engine oil applications it is also cataloged by Wix for some Allison Transmission applications.
If still in doubt you can contact Wix customer service and see which filter they recommend for your application.
USA: 1-800-949-6698
CANADA: 1-800-567-3703
MEXICO: 1-800-838-4204
  • KennyP, CRFarnsworth and bbstacker461 have said thanks
