Wanted
ARIENS GT POWER STEERING
for free
11 replies to this topic
#1 GT MIKE OFFLINE
GT MIKE
  • 4 Thanks
  • 4 posts
Posted January 08, 2021 - 12:05 PM
HELLO NEW TO THE SITE
I AM SEARCHING FOR A POWER STEERING COLUMN FOR AN ARIENS GT
  • afarmboy and jcp7hp have said thanks
#2 jcp7hp OFFLINE
jcp7hp
    ( ಠ ͜ʖಠ)
  • 1211 Thanks
  • 596 posts
Posted January 08, 2021 - 01:33 PM
Hello mike  :welcometogttalk: . Could you please tell us what ariens GT it is? Thank you.
  • afarmboy said thank you
#3 GT MIKE OFFLINE
GT MIKE
  • 4 Thanks
  • 4 posts
Posted January 08, 2021 - 05:04 PM
GT 20
KOHLER 20 MAGNUM CAST IRON BORE
M20s
49520768
931034001426
YEAR UNKNOWN
#4 dodge trucker OFFLINE
dodge trucker
  • 3886 Thanks
  • 4544 posts
Posted January 08, 2021 - 06:16 PM
that is teh engine numbers not the tractor numbers. The tractor model number will start with 931,
#5 runagun ONLINE
runagun
  • 65 Thanks
  • 65 posts
Posted January 13, 2021 - 11:23 PM
Earlier GT20, is the power steering shot on it? Is it leaking?
GT 20
M20s
49520768
931034001426
YEAR UNKNOWN
#6 GT MIKE OFFLINE
GT MIKE
  • 4 Thanks
  • 4 posts
Posted January 15, 2021 - 09:42 AM
931034 GT 20hp Lawn Tractor
The tractor is with the repair shop
The threads on the bottom fitting where the 4 hoses attach were bunged up enough that it leaked at the connections
Have solved that I think now need a gasket kit or suggestions for alternate for the bottom of the steering column
Is the steering column universal to all ariens gts or very from year to year
Thanks for the help
#7 dodge trucker OFFLINE
dodge trucker
  • 3886 Thanks
  • 4544 posts
Posted January 18, 2021 - 03:28 PM
I haven't looked at the ps on the gt19 in a few years, is the fitting that is screwed up removable or is it the threads in the housing?
I have heard that ps unit was the same as what deere put onto their 318 and maybe others, might open possibilities as to where to find them
#8 runagun ONLINE
runagun
  • 65 Thanks
  • 65 posts
Posted January 20, 2021 - 10:03 PM
you can send them in to get refurb.  Cost a few hundred bucks depends what they find wrong.
#9 dodge trucker OFFLINE
dodge trucker
  • 3886 Thanks
  • 4544 posts
Posted January 20, 2021 - 10:21 PM
I have an Ariens shop manual that has a section on teardown of one of those units...
where would somebody send one of those units in if it were needed?
I bring up the JD 318, the reason I know they used same unit is that I know someone that had to overhaul theirs..... I wasn't there for the carnage, though.
#10 GT MIKE OFFLINE
GT MIKE
  • 4 Thanks
  • 4 posts
Posted January 21, 2021 - 09:45 AM
Dodge Trucker and Runagun
Thank you for your response
There are 4 male threaded nubs at the bottom of the steering column
They seam to be pressed into the bottom plate which is held to the column with 4 bolts
There is a bleeder screw into one of the nubs
I would be interested in any information on where to get it rebuilt
I searched some columns on line for other tractor types but the ones that came up had 5 bungs
I will look into the JD318
Gravely used the same part number column but they also stopped manufacturing it
#11 runagun ONLINE
runagun
  • 65 Thanks
  • 65 posts
Posted January 21, 2021 - 03:31 PM
https://www.qccorp.c...r-applications/  these guys bought up the patents from parker.    call them they can service your hgf unit.
#12 dodge trucker OFFLINE
dodge trucker
  • 3886 Thanks
  • 4544 posts
Posted January 21, 2021 - 08:31 PM
can you either;
take that bottom plate off and have it tapped out for other fittings that would mate up with the hoses on the other side?
Find someplace that services these/sells parts and just buy that bottom plate with any associated gasket(s) /O-rings/seals?
Im not sure what would be under that plate, never been into one of those units.
Also tagged with one or more of these keywords: Wanted, for free
