Edited by 4getgto, December 20, 2020 - 02:15 PM.
Posted December 20, 2020 - 02:13 PM
Posted December 20, 2020 - 04:25 PM
Nice. Make sure you bolt it down to the floor or a really heavy built work bench. If you have a big Vice you can bolt 2 heavy pieces of L channel to the bottom and clamp it in your vice.
The smaller tires especially the older ones are a HUGE pain in the to change. I bent a decent sized crowbar taking an old rock hard Goodyear tire off. It was a 13x5.00-6 4 ply tire off of an old JC Penny that was so stiff that I ended up cutting the 2nd one off because it took 1/4 as long to do. I would of just changed the rims but the spindles were 1/2" instead of a normal 3/4" or larger that you usually see on a tractor that size.
Posted December 20, 2020 - 05:56 PM
Posted December 20, 2020 - 08:19 PM
I bought one about 15 years ago when they were on sale. It works well on small tires but the 12" and bigger I take to my regular car tire changer. If you change 12" tires on it, a couple of 10" tire spoons help a lot.
I mounted mine horizontally on the end of a very heavy work bench. It seems to work well that way. I've probably changed 50 or more tires on it and wish that it came with a third plastic spacer. Keep a couple of ratchet straps with it to help when inflating. Good Luck, Rick
Posted December 21, 2020 - 05:24 AM
Appreciate the feedback. I got this hoping it will make things easier on smaller tires meaning 6" 8" maybe 10". Any rim with a open center with lug nut bolt pattern a garage in town can do them much easier on a machine than me. 👍I bought one about 15 years ago when they were on sale. It works well on small tires but the 12" and bigger I take to my regular car tire changer. If you change 12" tires on it, a couple of 10" tire spoons help a lot.
Posted December 23, 2020 - 10:41 AM
Edited by 4getgto, December 23, 2020 - 10:46 AM.
Posted December 23, 2020 - 11:50 AM
Posted December 23, 2020 - 02:25 PM
A little update as my tires are "suppose" to here today and figured I'd get the old ones off. Just dismounting for now.
First tire came off great. Really excited I was. Almost too easy. The tire and rim were really clean and no rust so that was big plus. Worked great.IMG_20201223_091740.jpg
Second one NOT so much. Struggled mightily on this one. The bead breaker has a little to be desired. Even on the first tire a little. Second one I got one side pushed down but the other side wasn't happening. Had to pound that side down with a hammer and dull chisel . Just couldn't get it with their bead breaker.
The tool bar they give you to take the tire off rim works good even on the rusted tire and rim. So that was a big help.
Second wheel had slime in it, I bet!
Posted December 23, 2020 - 04:53 PM
Absolutely right Kenny..! 👍Second wheel had slime in it, I bet!
Posted January 02, 2021 - 11:21 PM
Worse part is I'm the guilty one...😖
Posted January 03, 2021 - 06:48 AM
Hey I’m actually about to go pick one up. I can’t see a single video or recording of anyone using another tube into the tire. I just wanna replace a tube. Will this work with replacing a tube? Thanks. Also, will this work with 23/8.50/12 tires? It says it can go up to 12 inch rims..
Posted Yesterday, 09:00 AM
I bought mine about three years ago, and wish I'd had one years before. It has saved a lot of skinned knuckles and bad words. It's one of the best things I've bought at Harbor Fright. I've changed probably a dozen or more tires with it so far.
Edited by thom, Yesterday, 09:01 AM.
Posted Yesterday, 09:56 AM
