Bolt sizes for weights on my 24/14
3 replies to this topic
#1 boboy OFFLINE
boboy
  • 26 Thanks
  • 48 posts
Posted November 22, 2020 - 09:46 AM
I got front and rear weights for my 24/14 and need to know size and length for front and rear? Assume i need carriage bolts?Weights appear to be Pk or Farmall cub. Thanks Bobby
  • MNGB said thank you
#2 MNGB OFFLINE
MNGB
  • 5068 Thanks
  • 2519 posts
Posted November 22, 2020 - 11:55 AM
I don't know about the front wts but the rear use a 5/8" carriage bolt and I think 2.5" just put a set on my 1620 and had to cut off the bolts I had in stock but don't recall what the exact length was not over 3" just looked at my work order but didn't enter what they were
  • boboy said thank you
#3 boboy OFFLINE
boboy
  • 26 Thanks
  • 48 posts
Posted November 22, 2020 - 08:21 PM
I estimated the rears were at least 4 1/2 inches long  and that shows what i know1 Thanks so much you are a wealth of knowledge! Bobby
#4 coxhaus OFFLINE
coxhaus
  • 344 Thanks
  • 277 posts
Posted November 24, 2020 - 08:34 PM
I used 1/2 inch x 2 inch bolts I bought at tractor supply for my front wheels weights for my PK 2414.  If you use smaller then when you take them off the carriage bolt will spin and be hard to remove.  I started with smaller bolts.  I think any bolt will hold them on.
I bought grade 8 just so they would not rust so bad.
Edited by coxhaus, November 24, 2020 - 08:37 PM.
  • MNGB and boboy have said thanks
