Starter motor number of teeth G11
8 replies to this topic
#1 heliosuk OFFLINE
heliosuk
  • 274 Thanks
  • 193 posts
Posted November 21, 2020 - 04:01 PM
Good evening guys, work continues with the restoration of my G11 in the UK and I need a starter motor. Can anyone tell me the number of teeth I need on the motor as am seeing various numbers. I think it should be 11 but not 100% sure.
  • afarmboy said thank you
#2 KennyP ONLINE
  • 51077 Thanks
  • 52668 posts
Posted November 21, 2020 - 04:08 PM
What engine is on it?
#3 heliosuk OFFLINE
heliosuk
  • 274 Thanks
  • 193 posts
Posted November 21, 2020 - 04:12 PM
Briggs 11HP. I bought it with a Lombardini  diesel in it which was terrible but had an 11HP Briggs in my spares shed so it that which is going into the G11 to bring it back to original.
Edited by heliosuk, November 21, 2020 - 04:14 PM.
  • KennyP and afarmboy have said thanks
#4 8tyman8 OFFLINE
8tyman8
  • 449 Thanks
  • 750 posts
Posted November 21, 2020 - 04:58 PM
Briggs an stratton engines with aluminum ring gears use a plastic starter gear to thats likely what it is if it's a steel ring gear I believe they are 10.or 12 teeth
#5 heliosuk OFFLINE
heliosuk
  • 274 Thanks
  • 193 posts
Posted November 21, 2020 - 05:24 PM
It's an aluminium starter ring gear.
#6 KennyP ONLINE
  • 51077 Thanks
  • 52668 posts
Posted November 21, 2020 - 05:37 PM
Can't remember what the tooth count on the plastic gears is. Got one out in the shop.
  • heliosuk and afarmboy have said thanks
#7 heliosuk OFFLINE
heliosuk
  • 274 Thanks
  • 193 posts
Posted November 22, 2020 - 12:30 PM
If you could check for me it would be much appreciated!
#8 KennyP ONLINE
  • 51077 Thanks
  • 52668 posts
Posted November 22, 2020 - 02:55 PM
I counted teeth this morning. 16 teeth on the plastic gear. Should be part # 695708,
  • heliosuk said thank you
#9 heliosuk OFFLINE
heliosuk
  • 274 Thanks
  • 193 posts
Posted November 22, 2020 - 03:01 PM
Thank you very much KennyP. I'll look for one over here.
