rear wheels & tires for my Power King, maybe
5 replies to this topic
#1 thom OFFLINE
thom
  • 1090 Thanks
  • 644 posts
Posted November 20, 2020 - 08:38 PM
I bought these wheels & tires thinking they might fit on my Power King. I don't yet know if the bolt pattern and center hole size is right. They are 15" instead of 16" like the originals but I don't think that will matter if all else is the same.
  • MNGB and jcp7hp have said thanks
#2 4getgto OFFLINE
4getgto
  • 5385 Thanks
  • 2088 posts
Posted November 21, 2020 - 05:38 AM
Are the red ones on the left the original. I see they're 6 lug and the white ones on the right are 5 lug. Not sure what you're looking for.?
15"-16"......5 lug- 6 lug ?
  • MNGB said thank you
#3 propane1 OFFLINE
propane1
  • 13089 Thanks
  • 5846 posts
Posted November 21, 2020 - 07:55 AM
Red ones look to be the same as rear wheels on a big wheel case 444, 446. Now those wheels are the same as on most farm tractor front wheels on a two wheel drive model. And I saw a kubota compact 4x4 tractor , front wheel were the same. Most two wheel drive older tractors front wheel size is 6-16. Six wheel stud holes and 6” apart.
Noel
  • Rock farmer, MNGB and 4getgto have said thanks
#4 MNGB OFFLINE
MNGB
  • 5068 Thanks
  • 2519 posts
Posted November 21, 2020 - 12:45 PM
The 15" 5 lug wheels will not fit the PK's used a 6 lug wheel 6X6 pattern as posted implement wheels case will work but only one way a the dish is different so will only go on in the wide setting, and truck wheel will not fit either
Edited by MNGB, November 21, 2020 - 12:46 PM.
  • propane1 said thank you
#5 Glenn Ayers ONLINE
Glenn Ayers
  • 172 Thanks
  • 151 posts
Posted November 21, 2020 - 12:54 PM
They might work .... just see if you can get 2 of the bolts to line up ... then bust the other ones off.
#6 thom OFFLINE
thom
  • 1090 Thanks
  • 644 posts
Posted November 21, 2020 - 04:40 PM
Nah, I realized that the white wheels were five lugs after I posted. Senior moment. :hitting_self_roller:  But I have discovered that the rears on the Power King are the same wheel that my local tractor dealer showed me, off the shelf, for the front of an 8N Ford. I can buy them from him for $72, in stock, no shipping, brand new, bare steel, ready to prime and paint. They measure and look identical to the rears on the PK except the holes where the weights would bolt on are round on the new Ford wheels and square on the PKs. A file will fix that.
  • propane1, MNGB and 4getgto have said thanks
