New to Me Rock Rake
rock rake sear 3 point
6 replies to this topic
#1 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 3818 Thanks
  • 2037 posts
Posted November 18, 2020 - 08:18 PM
I've been looking for a rock rake for my GT for several years,  I finally scored one today!  I found it on FB  marketplace for $75.  It is 46 inches long, Sears 3 point, adjustable angle, and complete.  I will change it to a standard Cat 0 3 point so I can use it behind my Cub 1811.
Here are some pictures of it.
This 3 point pin and top attachment arm are bent.
You have to look at this one sideways
I like that it's 46 inches in length.
Someone added these pipes to add extra weight.
I will have to see if I can find an owners manual for it.
Edited by Mark 149 J., November 18, 2020 - 08:19 PM.
  • KennyP, WrenchinOnIt, boyscout862 and 8 others have said thanks
#2 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 3818 Thanks
  • 2037 posts
Posted November 18, 2020 - 10:31 PM
I found a video on Youtube that shows the same model of rake but it has a wheel that attaches with an arm after the rake.  It allows for height adjustment.  I don't think I will need the wheel because I will be able to adjust the height with 3 point on my Cub.  I still haven't found an owners manual.
You can see the extension with part of the wheel showing in this picture.
Edited by Mark 149 J., November 18, 2020 - 10:32 PM.
  • KennyP, WrenchinOnIt, kjmweld and 1 other said thanks
#3 kjmweld OFFLINE
kjmweld
  • 3396 Thanks
  • 1283 posts
Posted November 18, 2020 - 10:57 PM
Looks like an arps made unit to me.
  • mark843, Mark 149 J. and jcp7hp have said thanks
#4 chieffan OFFLINE
  • 15855 Thanks
  • 8916 posts
Posted November 19, 2020 - 08:23 AM
I bought a new on with 3 point last spring from a Farm & home store.   We have several Hybred willow trees in our yard and they drop a ton of branches every winter.  The rake works great to gather them up and drop them in along row down a dirt drive, then lightening strikes them.   Use it behind the White 1655.  As long as you don't have down pressure on it just let it float and works good.
  • Mark 149 J. and jcp7hp have said thanks
#5 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 3818 Thanks
  • 2037 posts
Posted November 19, 2020 - 10:30 AM
Never heard of that company before.  I will have to check that one out.
Thanks
  • kjmweld said thank you
#6 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 3818 Thanks
  • 2037 posts
Posted November 19, 2020 - 10:33 AM
I've seen them used for raking up branches.  Good to know that they will work good for that.
I figured if it doesn't work well with just the 3 point I could add an adjustable wheel on each end.
Thanks
#7 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 20306 Thanks
  • 6839 posts
Posted November 19, 2020 - 03:03 PM
This may help you with how to set it up - probably not the same but similar style.
https://gardentracto...-rake-48624537/
Edited by 29 Chev, November 19, 2020 - 03:05 PM.
  • WrenchinOnIt and Mark 149 J. have said thanks
Also tagged with one or more of these keywords: rock rake, sear, 3 point
