Is a farmall cub or a cub lowboy considered a garden tractor?
26 replies to this topic
#1 Jcp7-8 OFFLINE
Jcp7-8
  • 66 Thanks
  • 82 posts
Posted October 14, 2020 - 09:43 AM
There's this big mystery iv'e always wanted to find out. Is the farmall cub and the cub lowboy considered a garden tractor? Why do you think what? All replies are thanked.
  • boyscout862 and Kster526 have said thanks
#2 diesel nut ONLINE
diesel nut
  • 1092 Thanks
  • 634 posts
Posted October 14, 2020 - 10:41 AM
If I remember correctly from the old paperwork International Harvester marketed them as a small farm tractor for small acreage farms that had 1-2 horses
  • Leonard VanCamp, Kster526 and Jcp7-8 have said thanks
#3 propane1 ONLINE
propane1
  • 12899 Thanks
  • 5797 posts
Posted October 14, 2020 - 10:56 AM
The way I kinda look at it is, any tractor with rear wheel size less than 24” wheel is a garden tractor. And any tractor with a 24” rear wheel and up is a utility tractor. As the rear wheel size gets above 30” let’s say, then things change again. Hard one to figure. Can’t be by engine hp, because a farmall cub has 9 1/2, hp where as garden tractors range from 8 or so to 25 hp. So I don’t really know how it’s figured out. Great question. Hope someone fill us in with some answers.
Noel
  • Kster526, DChappy and Jcp7-8 have said thanks
#4 DChappy OFFLINE
DChappy
  • 314 Thanks
  • 220 posts
Posted October 14, 2020 - 11:02 AM
Noel
When you say wheel size-I believe you are talking about tire diameter, basically on a 12" rim. I would say anything less than a 26x12x12 tire size, or more precisely 12" wheel.
  • oldiron, Kster526 and Jcp7-8 have said thanks
#5 propane1 ONLINE
propane1
  • 12899 Thanks
  • 5797 posts
Posted October 14, 2020 - 12:46 PM
I mean wheel diameter. Hope this helps. I just got a Case 446 a few weeks ago. Its no bigger than a garden tractor, like a MF 14, with 12" diameter rear wheels, but the Case has 16" diameter wheels on the rear. So, is the Case a garden tractor or a utility tractor or what is it ? And the MF 14 and the Case 446 are about the same weight.
Noel
#6 Leonard VanCamp OFFLINE
Leonard VanCamp
    Deere Herder
  • 949 Thanks
  • 637 posts
Posted October 14, 2020 - 02:23 PM
I'd say it's more of a small farm tractor directed at vegetable farms and municipal work. along the lines of a Allis Chalmers G, or a John Deere L,LA.
  • boyscout862, propane1, Kster526 and 2 others have said thanks
#7 coxhaus OFFLINE
coxhaus
  • 340 Thanks
  • 275 posts
Posted October 14, 2020 - 05:24 PM
I think the Power King tractors are garden tractors.  The 2414 has 24 inch tires so maybe a little larger tires than 24 inch to not be a garden tractor.
  • propane1, Kster526 and Jcp7-8 have said thanks
#8 poncho62 ONLINE
poncho62
    Hangin' with the cool kids
  • 3718 Thanks
  • 2453 posts
Posted October 14, 2020 - 05:36 PM
Modern tractors seem to come in 4 ranges
Lawn/Garden tractor
SCUT (Sub Compact Utility tractor)
CUT (Compact Utility tractor)
Full size tractor
The Farmall Cub and Lowboy seem to fit between the SCUT and CUT to me........JMO
#9 Kurtee OFFLINE
Kurtee
  • 659 Thanks
  • 501 posts
Posted October 14, 2020 - 05:48 PM
OK my take on this. In my feeble mind the garden tractors have Kohler, Briggs, Tecumseh or such single cylinder or twin for a power plant. The Cubs and other small tractors have 4 cylinder engines and trannys made by the tractor manufacturer. It drives the transmission with a direct connection and not a belt and also has a pto and possibly 3 point hitch. And yes I realize the Cub Cadet has a pressure plate clutch with a shaft to the transmission. The Cubs used the C Farmall rear end which is the reason they take the abuse that they do. Small engine generally air cooled is garden tractor in my book. A side note: my father said that Kohler was just about done in before the garden tractors took off.
#10 Kurtee OFFLINE
Kurtee
  • 659 Thanks
  • 501 posts
Posted October 14, 2020 - 05:50 PM
Lawn/Garden tractor
Full size tractor
agreed
Deere puts a MCUT between the SCUT and the CUT
  • Kster526 and Jcp7-8 have said thanks
#11 Cvans OFFLINE
  • 9335 Thanks
  • 7212 posts
Posted October 14, 2020 - 06:35 PM
The answer is simple, if your using it in the garden it's a garden tractor.  :D
  • DougT, pharmer, chieffan and 4 others have said thanks
#12 GardnMastr OFFLINE
GardnMastr
  • 667 Thanks
  • 318 posts
Posted October 14, 2020 - 08:00 PM
Garden tractors are defined as being able to pull one 12” moldboard breaking plow or less. It’s defined back in approximately 1912 or so. I first read it in the inside cover of Dave Baas’ first book. It makes sense to me. If you want me to look it up I can.
#13 GardnMastr OFFLINE
GardnMastr
  • 667 Thanks
  • 318 posts
Posted October 14, 2020 - 08:04 PM
I would separate lawn tractors and garden tractors. As a generality, lawn tractors are not capable of pulling ground engaging equipment, garden tractors certainly are.
#14 GardnMastr OFFLINE
GardnMastr
  • 667 Thanks
  • 318 posts
Posted October 14, 2020 - 08:26 PM
Dave considered only the Gibson “A”, of all the Gibson’s, fit the parameters of a garden tractor, it being capable of pulling that size plow or less. It had 16” rear tires. He thought the D and SD were too capable. Ever heard of a “4 bolt JD B”, they were marketed as garden tractors, I believe. Good topic, one I have thought about a lot. There has to be a dividing line somewhere, right. If I build a 4 wheel drive “garden tractor” and weight it heavy enough and build a 3 bottom plow with 6” bottoms for it to pull and it does it, is it a garden tractor? Back to the subject. No I personally don’t think of cub lowboys as being garden tractors. I like them though, I just categorize them differently in my mind.
#15 DougT ONLINE
DougT
    Dog Approved
  • 8299 Thanks
  • 5712 posts
Posted October 14, 2020 - 08:51 PM
And from there it depends on the size of the garden as to how big of equipment you need.
  • Cvans, Kster526, Mark 149 J. and 1 other said thanks
