Kohler 16 HP K341
2 replies to this topic
#1 MLW OFFLINE
MLW
  • 1 posts
Posted July 29, 2020 - 09:33 PM
What’s the difference between a K341S and a 341SA? Also how many fens does a thicker cylinder wall K341 engine have?
#2 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 17637 Thanks
  • 11583 posts
Posted July 30, 2020 - 05:58 AM
A shop manual, which you will find in the library above, will give you those answers.
#3 EricFromPa ONLINE
EricFromPa
  • 6296 Thanks
  • 4385 posts
Posted July 30, 2020 - 11:24 AM
A 13 fin block has a thicker cylinder wall which can be bored out to accept a 4.000" piston. Chevy 327 or 4.000" aftermarket piston. Even though a 350 piston is the same diameter the piston pin is located to low on the skirt to be used in a Kohler block. Piston will hit the head,to much popup.
Letter model designations are as follows:
Designates Oil Pan Type
EP = Generator Set
P =   Pump Model
Q =  Quiet Model
R =   Gear Reduction
S =   Electric Start
T =   Retractable Start
Edited by EricFromPa, July 30, 2020 - 11:28 AM.
  • DMAX, propane1 and fredh have said thanks
