Starting a nut in hard to reach spot tip
12 replies to this topic
#1 Alberta Bolens OFFLINE
Alberta Bolens
  • 1037 Thanks
  • 420 posts
Posted June 30, 2020 - 10:08 PM
This weekend while working on my 425 I had to start a nut in a place I can't get my pudgy little fingers. After struggling trying to get the nut to stay in the box end wrench while I tried to start the bolt. The light bulb came on. I used a piece of plastic wrapped over the nut to keep it tight in the box end. Of course don't cover side of the nut you want the bolt to go into. It keeps nut in place, once bolt is started you can still get wrench off.
I've have used silicone = messy. Magnets not always strong enough amongst various other methods. The plastic worked well
  • Alc, Bruce Dorsi, KennyP and 6 others have said thanks
#2 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5065 Thanks
  • 2885 posts
Posted June 30, 2020 - 10:50 PM
Paper also works as well as plastic in either the box end or open-end of a wrench.
  • KennyP, LilysDad, propane1 and 4 others have said thanks
#3 boyscout862 OFFLINE
  • 14955 Thanks
  • 9935 posts
Posted July 01, 2020 - 07:17 AM
Popular Science showed putting a piece of  masking tape over the back of the wrench to hold the nut. It has worked for me for over 53 years. Good Luck, Rick
  • daytime dave, Bruce Dorsi, KennyP and 5 others have said thanks
#4 chieffan OFFLINE
  • 15854 Thanks
  • 8916 posts
Posted July 01, 2020 - 07:36 AM
I use the masking tape or duct tape method.  Some times a piece of flat toothpick to wedge the nut to the box wrench.
  • pharmer, boyscout862, Mark 149 J. and 1 other said thanks
#5 IHCubCadet147 ONLINE
IHCubCadet147
  • 1787 Thanks
  • 795 posts
Posted July 01, 2020 - 08:11 AM
Works for me as well.
#6 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 18212 Thanks
  • 11729 posts
Posted July 01, 2020 - 08:43 AM
How about supergluing the nut to the tip of your finger?
  • chieffan, Mark 149 J. and 426tractorguy have said thanks
#7 secondtry ONLINE
secondtry
  • 4619 Thanks
  • 2773 posts
Posted July 01, 2020 - 09:22 AM
   I have used double sided tape. Don.t often have it on hand though.
  Don
  • chieffan and Mark 149 J. have said thanks
#8 chieffan OFFLINE
  • 15854 Thanks
  • 8916 posts
Posted July 01, 2020 - 04:01 PM
Not sure I want my finger in that hole all the time.
  • KennyP and LilysDad have said thanks
#9 Alberta Bolens OFFLINE
Alberta Bolens
  • 1037 Thanks
  • 420 posts
Posted July 01, 2020 - 09:11 PM
Oh never thought of using duct tape.
#10 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 20299 Thanks
  • 6839 posts
Posted July 02, 2020 - 04:46 PM
Sometimes a piece of mechanics wire wrapped around the body of an open end wrench and then formed to go up one side of the nut and catch over the top of the hex where the wrench is open will hold the nut in place but still allow some wiggle room to start the nut onto a bolt thread as well in a situation where you can turn the bolt but not the nut because of space restrictions.
#11 Dee OFFLINE
Dee
  • 357 Thanks
  • 214 posts
Posted November 14, 2020 - 08:12 PM
This is an old thread but I'll toss in another trick I had to use recently.  While replacing the metal roof panels on my garden shed I had to start a nut on a small bolt that sits right above a roof beam.  Not enough  room for fingers or pliers to start the nut at all.
So, I had to get creative and was successful by putting the nut on the end of a screwdriver with a magnetic tip.  Holding the tip of the screwdriver against the end of the bolt I was able to spin the nut with just the tip of my finger until it would catch a thread .
Once started, I could continue spinning the nut with my finger tip until it was on solid.  To finish I had to put a small pliers on the nut, tape the pliers against the panel and go back up top and turn the bolt tight from above.
Ended up doing dozens of them that way.
  • KennyP, Vrdaddy and IHCubCadet147 have said thanks
#12 426tractorguy OFFLINE
426tractorguy
    infowars.com
  • 807 Thanks
  • 514 posts
Posted November 18, 2020 - 07:07 PM
show pictures?
#13 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 18212 Thanks
  • 11729 posts
Posted November 19, 2020 - 07:53 AM
I have an Ingersoll snow blower. It n't has a chute that is held in place by three clips. One of them is directly in front facing the up turned front of the shroud. Stupid idea! It was almost impossible to get a rachet with a 1/2" socket on. No, a wrench didn't fit. A socket was too short. A deep well, too long. Hmmm . . .     I ended up putting a 1/4" socket on an adapter to a 3/8 wrench. Perfect!
  • IHCubCadet147 said thank you
