* * * * * 2 votes
Upgrades and Repairs to the 1477 Forklift
47 replies to this topic
#1 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5039 Thanks
  • 1208 posts
Posted June 27, 2020 - 06:23 PM
Decided to install a NOS PS unit I’ve had laying on the shelf. I knew I’d have to remove the roll cage and pedal engagement mechanism to get the fender pan off , a further challenge was the forklift seat support and the pump brackets were in the way so I had to make new hard lines had the 3/8” tube in 304 SS so used it. I also needed to shim out the rear mount as the vertical seat support covers one of the bracket mounting holes. Tight quarters behind the engine fire wall and steering cowl ,ended up freeing up the steering cowl ( unbolt and tilt back ) and disconnect the steering shaft from the steering bridge to access the flow diverter port and be able to fit a wrench in there to work on the valve. Upside it will make it easier to change out the back engine mounts. Changed the tie rod ball joints while I was at it. Pleased with the results.
Edited by WrenchinOnIt, June 27, 2020 - 07:42 PM.
  • Bolens 1000, blackjackjakexxix, KennyP and 8 others have said thanks
#2 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5039 Thanks
  • 1208 posts
Posted June 27, 2020 - 06:33 PM
Been very dissatisfied with the tires those skinny fronts (rears ?) sink sink sink once off the hard pan , my buddy Rick Show ( blackjackjake) found me some of the wider 10” wheels so into the blast cabinet they went , gave the inside some POR 15 , decided on Carlisle Industrial 20x10x10’s. Mounted them up. Like it a lot better now.
Edited by WrenchinOnIt, July 28, 2020 - 03:45 PM.
  • Bolens 1000, Alc, blackjackjakexxix and 11 others have said thanks
#3 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5039 Thanks
  • 1208 posts
Posted June 27, 2020 - 06:36 PM
Front (rear?) Motor mounts replaced. WIP on the other two
  • Bolens 1000, blackjackjakexxix, KennyP and 7 others have said thanks
#4 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5039 Thanks
  • 1208 posts
Posted June 27, 2020 - 06:40 PM
Rears (fronts?) not a R4 fan. Wanted USA made and something that looked like it belonged on a GT. Decided on the new Goodyear R14’s. Need to clean and paint the duals and mount them up. Thinking I’m going to add another set of weights to it.
Edited by WrenchinOnIt, June 27, 2020 - 07:18 PM.
  • blackjackjakexxix, KennyP, Austen and 8 others have said thanks
#5 kjmweld OFFLINE
kjmweld
  • 3373 Thanks
  • 1275 posts
Posted June 27, 2020 - 07:27 PM
What a game changer on those front Carlisle's, those really set it off as "tall & proud." I'm sure they'll make a huge difference as well. Super nice clean install on those lines you made up. Pictures make it look easy, but I know that wasn't an easy task to pull off. Awesome upgrades Kevin, I love it 👌👍
  • blackjackjakexxix, WrenchinOnIt, Austen and 1 other said thanks
#6 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted June 27, 2020 - 08:34 PM
Looks amazing Kevin, everything you do is just pure perfection.
  • blackjackjakexxix, WrenchinOnIt, Austen and 2 others have said thanks
#7 Austen OFFLINE
Austen
  • 3529 Thanks
  • 1420 posts
Posted June 27, 2020 - 09:53 PM
Some large frame action from Kevin, what could be better, this evening got a lot whole more interesting! :) Great upgrade, I'll bet you wonder how the previous owner lived without PS before. I suppose, though, that in this setup unlike your other one (formerly Dave's) that the weight is over the backend so steering may not be as heavy as you might think, or even lighten up some with heavy loads. In any case, forklift duties usually include constant maneuvering so PS is an obvious upgrade anyway you look at it. That's so cool you had an early system, color period correct, that you could add to it. :thumbs:
Thanks for walking us through the process too. Making those lines and everything would take a lot of time and precision. As mentioned in your other thread, I like the look of your new front tires. The wider style I think goes better on a forklift. I remember when you added the duals, that was a fitting addition to it as well and makes an already very unique machine even more more to look at. Please post some updated pics once you get the new shoes mounted up on the rear.
How tall is the cage? It looks tall but hard to get perspective without seeing in person.
BTW, there's just something about this pic. It looks frame worthy.
  • blackjackjakexxix, KennyP, WrenchinOnIt and 3 others have said thanks
#8 nkaust OFFLINE
nkaust
    Deere Hunter
  • 291 Thanks
  • 268 posts
Posted June 28, 2020 - 05:21 AM
man that thing looks mean, hard to beat the old bolens lol
  • blackjackjakexxix, WrenchinOnIt and greenhouse guy have said thanks
#9 firedudetl1 OFFLINE
firedudetl1
  • 706 Thanks
  • 439 posts
Posted June 28, 2020 - 09:59 PM
looks great - nice job - how difficult is it to bend that ss tubing? I see one handle in the vise and I'm wondering if you've got a "cheater" on the other handle to bend it? I've got some lines to replace on my old Bobcat 371 and you've given me some guidance, so thanks for that
again great job!
#10 firedudetl1 OFFLINE
firedudetl1
  • 706 Thanks
  • 439 posts
Posted June 29, 2020 - 06:32 AM
just looking again at the tubing pictures - did you do the fittings on the ends or were they purchased w/the fittings - nice neat job of adding them to the system
  • blackjackjakexxix and WrenchinOnIt have said thanks
#11 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5039 Thanks
  • 1208 posts
Posted June 29, 2020 - 07:50 AM
Thanks Ken, yup line installation had its moments
Thanks John, Ha! Too kind , often my expectations surpass my ability
Thanks Austen. Hoping it makes a difference in the steering cause I’m contemplating adding some mass to em.  The cage is slightly over 7’ tall I’ll get you a good measurement when it’s reassembled. Need to get the jack handle outta the pic first tho aye ?
Thanks ! I agree !
again great job!
Not difficult at all, no cheater needed on this. It’s vise mounted just to hold and level it. Much easier when you’re laying out bends based on axis and plane. Also that particular tubing comes in 6’ lengths
Nut and Ferrell are separate pieces. You should always slide the Ferrell on before flairing if you’ve put a bend in it . Nut will slide past bends Ferrell won’t.
The black bender is a Parker and for 3/8” only. It’s HD , precise and worth the price IMO , flat handles allow for vise clamping. Blue bender is handy for “field” bends on lighter wall tubing. A Hydraulic flare is 37-1/2 degrees ( tools listed at 37) couple flaring tools pictured. The Ridgid is a “wobble” flairing tool and IMO worth the money if your going to use a heavy wall tubing and/or continue to do some installs.
Edited by WrenchinOnIt, June 29, 2020 - 12:46 PM.
  • Alc, blackjackjakexxix, Austen and 4 others have said thanks
#12 firedudetl1 OFFLINE
firedudetl1
  • 706 Thanks
  • 439 posts
Posted June 29, 2020 - 09:55 AM
thanks for the info and extra pictures - someplace in my collection of seldom used tools I have a flare kit. not sure of the brand but I used it years ago to do brake lines for one truck or another.
If I get to doing the Bobcat lines, I'll invest in the better tools you've listed - thanks again
  • blackjackjakexxix and greenhouse guy have said thanks
#13 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5039 Thanks
  • 1208 posts
Posted June 29, 2020 - 12:31 PM
Just in case it’s needed info : brake lines are 45 degree flare unless AN ( Army Navy) fittings , they like hydraulics are 37 degrees. Also most Brake lines  use a double flare , hydro lines single.
Edited by WrenchinOnIt, June 29, 2020 - 12:39 PM.
  • blackjackjakexxix, Mark 149 J. and greenhouse guy have said thanks
#14 firedudetl1 OFFLINE
firedudetl1
  • 706 Thanks
  • 439 posts
Posted June 29, 2020 - 12:37 PM
thanks again - will check what flare angles I have in the kit - maybe just the 45s
#15 Bolens 1000 OFFLINE
  • 17383 Thanks
  • 18825 posts
Posted June 29, 2020 - 06:56 PM
Very Nice
