Can someone answer a few questions about allis 300 &400 series tractors?
#1
OFFLINE
Posted June 13, 2020 - 11:08 PM
But under the sheet metal it sure looks like a simplicity. I have only seen pictures. Help
#2
ONLINE
Posted June 14, 2020 - 08:39 AM
PTO is on front motor shaft ( opposite of flywheel side) Some models had electric clutch and some were manual with a mule drive. Tractor was a Simplicity design with most drive line component interchangeable. Kohler engine vs Briggs on Simplicity Landlord of same 1970-1973 era. Mower deck on Allis was right hand discharge instead of left hand on the Landlord. Sheet metal was completely different.
- Orangeace1 said thank you
#3
OFFLINE
Posted June 16, 2020 - 03:00 PM
300 and 400 came with 2 different gear box set ups one was a 3 speed forward with one reverse speed the other a 4 speed with a shuttle set up all 4 forward and reverse most parts will interchange between the 300 and 400 models the attachments for most other models of same size were the same however the mounting brackets changed .the 300 and 400 have a different front axle also
#4
ONLINE
Posted June 16, 2020 - 07:41 PM
Don't forget the hydro version!
#5
OFFLINE
Posted June 19, 2020 - 12:33 PM
The 300/400 was not a Simplicity design, but an Allis design. Aside from the bevel gear box and transaxle, everything else is exlusive to the AC design.
There is no 'center' PTO, per say. Though the clutch for the rear PTO attachments is off the bevel gear box like a Simplicity, there were no mid mounted attachments that used it. The front PTO was electric and used for mid and front attachments.
Electric lift is more commonly found on the 300's. The 300 series numbered several more models than the 400 series. The 300 series offerd 16 different model numbers. 8 per drive type, and then a variant for factor equipped power lift models. The 400 series totalled 5 models. The 300 series utilized the 3-speed and variable transmissions on non-hydro models, while the 400 series offered the 3-speed and shuttle transmissions on non-hydro's.
Of the 300 series, the 312H seems to be lowest production. Of the 400 series, the 414S is least common. Of all 300/400's, the 414S seems to be the rarer of the bunch, as it only appeared in the last of the 400 series literature and is most scarce.
310 (3-speed), 310D ('Delux', Variable), 312, 312D, 312H (Hydro), 314, 314D, 314 Hydro
410 (3-speed), 410S (Shuttle), 414S, 416S, 416H
#6
OFFLINE
Posted June 21, 2020 - 03:58 AM
#7
ONLINE
Posted June 21, 2020 - 11:49 AM
Cover-up was a better description then design. Allis-Chalmers purchased Simplicity in 1965, and Simplicity's management bought it back in 1983. When AC bought out Simplicity they violated U.S. anti-trust laws for becoming a monopoly. AC made cosmetic and engine changes and altered part numbers to make them look like AC propriety numbers. The basic design was still Simplicity. The Allis-Chalmers 314 can be referenced in the Simplicity catalog by codes 1600049, 1600050 (electric pto/lift), and 1600051 (hydrostatic).
#8
OFFLINE
Posted June 22, 2020 - 03:34 AM
I figured I'd start here before I go to Ebay. I have a 416H that has been setting for years. It ran perfect before I parked it in the barn and went off to serve our country. My intentions over the years was to blow off the dust and get her fired back up. As all good plans go, something else always got in the way. Now time and age have got away from me to.
I know I could part it out because many parts are hard to come by. However, the old girl would love to stay in one piece and go to work on someone else's acreage. I know these are classic tractors and getting harder to find.
So, if anyone is interested shoot me a message. I can always send some pictures as well. I just don't have them now.
I guess I need to start liquidating some stuff before my kids have to deal with the mess.
God Speed everyone,
#9
OFFLINE
Posted June 25, 2020 - 08:29 AM
Not true. Allis violated nothing by purchasing Simplicity at that time. What is true is that the government intervention was nearing it's peak by '68, and they were forced to adapt after the FTC issued its Horizontal Merger Guidelines. For the first few years laws were challenged in litgation, and so Allis tractors remained rebadged Simplicity designs, via the Lexington plant. The 300 series was the first completely new design, as forced by that ending litigation. AC was not the only company impacted, and so a ton of political pressure built until some anit trust laws were revised/repealed. There are countless suits from the '60's and '70's challenging anti trust enforcement, touching nearly every industry, product and service.
If you have ever looked over a 300 or 400 series, you would see that they share very, very little in common with any Simplicity. Remove the trans, wheels and a few bushings and bearings, and every part is completely different, not in part number alone, but in size, shape...design.
- KennyP, AllisKidD21 and bigdee have said thanks
