Troy Bilt Super Bronco -Improved Steering
steering bearings tires super bronco troy
4 replies to this topic
#1 buffaloman2 OFFLINE
buffaloman2
  • 3 posts
Posted June 13, 2020 - 12:32 PM
I have a 2015 Troy Bilt Super Bronco that I use to mow about 1+ acre. The area has many trees, garden/flower beds,etc. The steering, especially at slow speeds, is difficult to turn. Has anyone developed a poor man's power steering or lower drag for turning?
I once read about using roller bearings instead of bushings but I lost that info & don't know if would even work.
#2 IHCubCadet147 OFFLINE
IHCubCadet147
  • 2408 Thanks
  • 955 posts
Posted June 13, 2020 - 08:23 PM
Do you regularly grease the steering components? If not, that may be a good place to start.
  • AGMANN said thank you
#3 gears OFFLINE
gears
  • 148 Thanks
  • 93 posts
Posted June 14, 2020 - 06:51 AM
I’ve seen Torrington bearing kits to replace the lower washer for some machines. Picture a thin needle bearing disc, with the needles radially placed - like sunbeams in a kids drawing, sandwiched between two thin hardened washers.
#4 gears OFFLINE
gears
  • 148 Thanks
  • 93 posts
Posted June 14, 2020 - 07:12 AM
Measure your spindle diameter that goes through the front axle, 5/8” is common, so is 3/4”.
Found this on amazon if you search.... TC1018 Thrust Needle Roller Bearing 5/8 x 1 1/8 x 5/64 inch Thrust Bearings
#5 VTXrider OFFLINE
VTXrider
  • 709 Thanks
  • 525 posts
Posted June 14, 2020 - 12:32 PM
I use McMaster Carr Thrust bearings on all my tractors with two .032 washers. It does help some but smooth front tires help the most.
https://www.mcmaster...atalog/126/1274
Also tagged with one or more of these keywords: steering, bearings, tires, super, bronco, troy
