Made a score today! JD 54/56 blade!
54 blade
71 replies to this topic
#61 4getgto ONLINE
4getgto
  • 4741 Thanks
  • 1931 posts
Posted September 14, 2020 - 05:39 PM
We usually don't get enough to mess with. Temps warm up and melt most of it.
I can't talk for all us Northernmost guys but I'll say after the 2nd or 3rd snow it's not that much fun anymore..!
  • KennyP and kjmweld have said thanks
#62 KennyP ONLINE
  • 50117 Thanks
  • 52293 posts
Posted September 17, 2020 - 03:51 PM
Started applying some finish paint to things the last couple days. I got the back side of the blade primered.
Got some other parts done up.
And the first coat on the back side.
Gotta flip it over and prime then paint the front side. When it's dry enough, I'll flip it and finish the back side. This sucker is heavy!
  • Mark 149 J., kjmweld, 4getgto and 1 other said thanks
#63 nkaust OFFLINE
nkaust
    Deere Hunter
  • 274 Thanks
  • 258 posts
Posted September 18, 2020 - 06:06 AM
Whoa its been a little while, but anyways hello again guys. looking good as always kenny. any plans to find parts to make that beast an h2?
#64 KennyP ONLINE
  • 50117 Thanks
  • 52293 posts
Posted September 18, 2020 - 06:43 AM
Thinking about adding a 3-spool after the single spool. No way to just change the valve as the steering is in the way of the linkage. Unless I get real creative with it.
  • 4getgto said thank you
#65 Leonard VanCamp ONLINE
Leonard VanCamp
    Deere Herder
  • 932 Thanks
  • 632 posts
Posted September 18, 2020 - 09:02 PM
You should be able to get a two spool to fit, your 316 is just like a 318, just two horses and a spool short. You could also put a electric solenoid valve in the hydraulics and use a switch to select which function you want.
#66 KennyP ONLINE
  • 50117 Thanks
  • 52293 posts
Posted September 19, 2020 - 04:24 AM
Except the 318 is power steering, not manual. And my 316 has a P220 in it.
#67 KennyP ONLINE
  • 50117 Thanks
  • 52293 posts
Posted September 19, 2020 - 12:48 PM
Here's more on the painting. Front side:
Got it flipped over and another coat on the back:
Saved a couple decals, including this one:
Couldn't save the 2-legged deere, though.
  • 29 Chev, kjmweld and IHCubCadet147 have said thanks
#68 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 19397 Thanks
  • 6576 posts
Posted September 19, 2020 - 01:15 PM
Very nice job - hope you get some white stuff to try it out on but I imagine that you will probably only get to play in the dirt with it.
#69 KennyP ONLINE
  • 50117 Thanks
  • 52293 posts
Posted September 19, 2020 - 01:59 PM
Most likely!
#70 KennyP ONLINE
  • 50117 Thanks
  • 52293 posts
Posted September 21, 2020 - 04:53 PM
Since this blade is a heavy-weight, I decided to make something to hold it upright and let me move it if needed. Found some 3/8" X 1-1/4" bar stock. Added a couple 2 X 2 X 3/16"  angle iron and I have a decent stand! Before paint and tacked together.
Did the finish welding:
Got them painted and installed:
  • Trav1s, hdg4400, Leonard VanCamp and 3 others have said thanks
#71 nkaust OFFLINE
nkaust
    Deere Hunter
  • 274 Thanks
  • 258 posts
Posted September 27, 2020 - 06:49 AM
looking good man, are you planning on redoing the 316?
#72 KennyP ONLINE
  • 50117 Thanks
  • 52293 posts
Posted September 27, 2020 - 07:03 AM
I'd have to have a different hood to make it right. With no shows going on down here, hard to find things, Like to find a 318 parts tractor and swap it all to it.
