Made a score today! JD 54/56 blade!
54 blade
77 replies to this topic
#46 KennyP ONLINE
  • 53259 Thanks
  • 53345 posts
Posted August 11, 2020 - 03:46 PM
Now I see what I need for the most part. Thanks for the pics and yes I'll add the 54/56 blade to the title.
  • Simpleton and secondtry have said thanks
#47 KennyP ONLINE
  • 53259 Thanks
  • 53345 posts
Posted September 02, 2020 - 08:58 AM
I have figured out what I will do for the bottom of the blade. Hard to explain so will do pics as I am rebuilding that part. Should work just fine. Hope to get back to this soon.
  • 4getgto said thank you
#48 KennyP ONLINE
  • 53259 Thanks
  • 53345 posts
Posted September 06, 2020 - 02:23 PM
Hard to explain, but this will attach at the bottom for the 'cutting edge' to bolt to. It's 1.25" X .1875" strap at an angle. Really 1.125" tall. Be a while before this is welded in as I have to even up the bottom edge to do that.
  • 29 Chev, Mark 149 J. and 4getgto have said thanks
#49 Trav1s OFFLINE
Trav1s
  • 4096 Thanks
  • 4921 posts
Posted September 07, 2020 - 03:54 PM
That looks nice!
#50 KennyP ONLINE
  • 53259 Thanks
  • 53345 posts
Posted September 07, 2020 - 03:57 PM
That looks nice!
It should work. Won't be buying JD replacement parts though!
  • Trav1s and Mark 149 J. have said thanks
#51 KennyP ONLINE
  • 53259 Thanks
  • 53345 posts
Posted September 09, 2020 - 04:57 AM
I got the blade up on sawhorses (heavy sucker) and put a line where I needed to trim it.
Fired up the cutting wheel and went to work.
Once it was trimmed, I made a v-groove between the blade and support. Clamped it together and welded that up. Had plenty of debris to clean out first.
Got that smoothed back down.
Today is fitting the new part for welding.
  • 29 Chev, Mark 149 J., 4getgto and 1 other said thanks
#52 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22858 Thanks
  • 7561 posts
Posted September 09, 2020 - 08:06 AM
Looks like you are giving it some long overdue love and attention - going to be a "heavier sucker" when you are done though so please be careful when you set it back down with gravities help.
  • KennyP, Trav1s and Mark 149 J. have said thanks
#53 KennyP ONLINE
  • 53259 Thanks
  • 53345 posts
Posted September 09, 2020 - 09:31 AM
Lot easier to get it down!
  • 29 Chev said thank you
#54 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 18406 Thanks
  • 7729 posts
Posted September 09, 2020 - 10:45 AM
Better hurry op and get it done in time for snow plowing Kenny!!   :D  :D  :D  :D
#55 KennyP ONLINE
  • 53259 Thanks
  • 53345 posts
Posted September 09, 2020 - 11:07 AM
No rush here!
#56 KennyP ONLINE
  • 53259 Thanks
  • 53345 posts
Posted September 11, 2020 - 02:30 PM
Only light showers today, so I tackled this again. Got the 'new' parts tacked in place.
Welded the back solid then laid it down to do the front seam.
After the grinder and flap wheel:
  • gopher, Leonard VanCamp, Mark 149 J. and 2 others have said thanks
#57 KennyP ONLINE
  • 53259 Thanks
  • 53345 posts
Posted September 13, 2020 - 08:27 AM
No pics, but yesterday I used a flap disc on the front side to clean most of the rust off and gave it a coat of Rust Reformer. About ready to put it together and figure out the mount for the lift cylinder. I'll bring my new trailer up to set the tractor and plow on for mocking that all up. There will be pics for all that.
  • Trav1s and kjmweld have said thanks
#58 KennyP ONLINE
  • 53259 Thanks
  • 53345 posts
Posted September 14, 2020 - 04:17 PM
I used the new trailer for a good flat surface to finish up the blade lift. Worked real good.
Allowed me to get things going in the right direction.
Found the measurements I needed and got the lift cylinder mounted. I have 7.5" of lift.
Here's the upper mount.
  • DMAX, Mark 149 J., kjmweld and 1 other said thanks
#59 kjmweld ONLINE
kjmweld
  • 3601 Thanks
  • 1331 posts
Posted September 14, 2020 - 04:53 PM
Nice work Kenny. That looks like it'll work well. Good timing in getting that about done now so you're prepared before needed. 👌
#60 KennyP ONLINE
  • 53259 Thanks
  • 53345 posts
Posted September 14, 2020 - 04:56 PM
We usually don't get enough to mess with. Temps warm up and melt most of it.
