Made a score today! JD 54/56 blade!
54 blade
71 replies to this topic
#16 KennyP ONLINE
  • 50090 Thanks
  • 52280 posts
Posted June 22, 2020 - 01:43 PM
Not sure if these will help you or not
The last one comes close, but it's blurred real bad.
  • 29 Chev said thank you
#17 KennyP ONLINE
  • 50090 Thanks
  • 52280 posts
Posted June 22, 2020 - 01:50 PM
While waiting for mower parts to arrive, I decided to repair the skid shoes for this. They were in bad shape.
Found some stock and bent the ends to match.
Trimmed the originals for a band saw cut.
Trimmed the excess off the 'new' parts.
Ground some bevels and welded them together.
After a massage with the flap disc.
  • 29 Chev, Mark 149 J. and IHCubCadet147 have said thanks
#18 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 19365 Thanks
  • 6566 posts
Posted June 22, 2020 - 02:31 PM
How about these?
#19 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 19365 Thanks
  • 6566 posts
Posted June 22, 2020 - 02:33 PM
How about these?
Edited by 29 Chev, June 22, 2020 - 02:35 PM.
  • KennyP, Leonard VanCamp and Mark 149 J. have said thanks
#20 KennyP ONLINE
  • 50090 Thanks
  • 52280 posts
Posted June 22, 2020 - 03:02 PM
That's good, but I need to know the hole location as marked here:
Can't tell if it's 1", 1-1/4", or 1-1/2" over to it.
  • 29 Chev and Mark 149 J. have said thanks
#21 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 19365 Thanks
  • 6566 posts
Posted June 23, 2020 - 12:06 PM
Can't give you an exact answer but I did some guesstimating using squares on the picture in case someone doesn't come up with a better answer.  I assumed that the two holes at the left side are 1/2" diameter ( I realize that the back one for the cylinder is slotted a bit) and made each square represent 1/2".  Given the camera angle and distortion it may be off a bit but you can check out the distance between the centre pivot bolt and the two edges to see if that distance is in the ball park - may help you a bit.
#22 KennyP ONLINE
  • 50090 Thanks
  • 52280 posts
Posted June 23, 2020 - 12:54 PM
Thanks, Stew. But it's not correct. The part is 10-1/4" wide, making the center pivot hole at 5-1/8". That hole is 3/4". Those other two are probably 1/2", I know the one closest to the bend up is. I don't want to weld this in to find out it's wrong/won't work right. Plus it's easier to drill those holes on the drill press. Someone will come up with what I need, I'm not in a big rush anyway.
  • 29 Chev and 4getgto have said thanks
#23 kjmweld ONLINE
kjmweld
  • 3192 Thanks
  • 1212 posts
Posted June 23, 2020 - 01:33 PM
Kenny, do you have, or can you get this bracket? Everything will fall into place if you can get that. Or was your plan to make that part as well?
#24 KennyP ONLINE
  • 50090 Thanks
  • 52280 posts
Posted June 23, 2020 - 03:31 PM
I planned to make that, but may have to see about buying one. The 316 has only one spool, so angle will be manual for now.
  • kjmweld said thank you
#25 KennyP ONLINE
  • 50090 Thanks
  • 52280 posts
Posted June 23, 2020 - 03:38 PM
Just checked and Mother Deere wants nearly $150 for that part! Not in my budget!
  • kjmweld and 4getgto have said thanks
#26 Compact7 OFFLINE
Compact7
  • 29 Thanks
  • 31 posts
Posted June 23, 2020 - 05:49 PM
I''ll take a crack at it. I've used Photoshop's selection tool info box before to extrapolate dimensions from photos.
First I rotated the image to horizontal to reduce angular error. Then I scaled the image so within the side plates was 10.25" and verified the halfway mark was 5.125. Then a second selection to the center of the hole in question gave me 1.125" or one & one-eighth inch. A little screengrab, copy/paste and this composite image shows both selections with photoshop's measurement of the length. Ta-Da!
So it can't be too far off from that mark.
Edited by Compact7, June 23, 2020 - 05:57 PM.
  • KennyP, 29 Chev, Mark 149 J. and 1 other said thanks
#27 KennyP ONLINE
  • 50090 Thanks
  • 52280 posts
Posted June 23, 2020 - 06:01 PM
That looks pretty close. Thank you.
  • Mark 149 J., kjmweld and 4getgto have said thanks
#28 KennyP ONLINE
  • 50090 Thanks
  • 52280 posts
Posted July 29, 2020 - 12:09 PM
Using the data Compact7 supplied above, I went to work on the 'new' part this morning. I have it welded together now and can start working on this again as time allows.
  • 29 Chev, Mark 149 J., kjmweld and 2 others have said thanks
#29 KennyP ONLINE
  • 50090 Thanks
  • 52280 posts
Posted July 29, 2020 - 05:11 PM
Took about 30 minutes and I had it dissected.
Next up was smoothing old welds.
Got to try to get this back closer.
Best I can get.
  • Leonard VanCamp, Mark 149 J., kjmweld and 2 others have said thanks
#30 KennyP ONLINE
  • 50090 Thanks
  • 52280 posts
Posted July 30, 2020 - 01:50 PM
I put the parts back into the blade to help in locating them. Got them aligned well and tacked it all. Took it back out and finished the welding. Rechecked fit and all is good. Gave it a coat of Rust Reformer for now.
Also coated the feet.
  • 29 Chev, Mark 149 J., kjmweld and 1 other said thanks
