Anyone "ever"seen a Briggs opposed twin with sheared key
5 replies to this topic
#1 Gilsonguy1150 OFFLINE
Gilsonguy1150
  • 5 Thanks
  • 15 posts
Posted June 03, 2020 - 02:20 PM
I have a 18 hp Briggs opposed twin that has great compression ,new coil,and rebuilt carb but will not start.paid 75 for the tractor.guy said it just quit.seems out if time.will not even hit on carb cleaner.anyone seen a sheared key on these motors?
  • chieffan said thank you
#2 coldone OFFLINE
coldone
  • 1709 Thanks
  • 1709 posts
Posted June 03, 2020 - 04:14 PM
Got Spark?
#3 Gilsonguy1150 OFFLINE
Gilsonguy1150
  • 5 Thanks
  • 15 posts
Posted June 03, 2020 - 04:41 PM
Yessss
  • boyscout862 and chieffan have said thanks
#4 boyscout862 ONLINE
  • 14731 Thanks
  • 9838 posts
Posted June 03, 2020 - 10:02 PM
When in doubt go through the troubleshooting sequence in the B&S manual. Then pull the flywheel and replace the key. Clean everything while you are in there. I often find a mouse nest. Good Luck, Rick
#5 DougT ONLINE
DougT
    Dog Approved
  • 8272 Thanks
  • 5690 posts
Posted June 04, 2020 - 04:31 PM
Got Spark?
With the magnetron ignition you would have spark regardless if the key is sheared. It would just affect the timing.
#6 Gilsonguy1150 OFFLINE
Gilsonguy1150
  • 5 Thanks
  • 15 posts
Posted June 04, 2020 - 05:29 PM
I've never seen a opposed twin with a sheared key.seems like it would be a pain to take the flywheel off
