pulling tractor build
4 replies to this topic
#1 Banjopicker10 OFFLINE
Banjopicker10
  • 524 Thanks
  • 317 posts
Posted May 29, 2020 - 03:09 PM
I've decided I am going to build a pulling tractor from a jacobsen homelite(basically a ford lgt 145) I am putting a 32 hp kohler k399-2t 2 stroke inline two cylinder in it since it didn't have the original k321 in it it has a two speed hydrostatic shaft drive transmission in it I was wondering if you thought it was worth it or if I should use something else to build a puler It will have a wheel horse body on it.I was also wondering if it would be worth putting turbo on it in the future.
  • 4getgto and Vrdaddy have said thanks
#2 Chris11 OFFLINE
Chris11
    old Member
  • 1730 Thanks
  • 1007 posts
Posted May 30, 2020 - 06:15 AM
you are better off building something like a older cub no hydo trans.
  • Banjopicker10 said thank you
#3 Rbertalotto OFFLINE
Rbertalotto
  • 65 Thanks
  • 33 posts
Posted May 31, 2020 - 05:57 AM
Go here....
http://gardentractor...s.com/index.htm
Read, Read, Read....This is a GREAT web site for GT Pulling.
BTW...You want hasrd gears....Belt and Hydro simply is not competitive. This fellow actually lists the Cub Cadet tractors you want to use.
#4 Banjopicker10 OFFLINE
Banjopicker10
  • 524 Thanks
  • 317 posts
Posted May 31, 2020 - 04:03 PM
Go here....
I would have used a cub but I couldent find one and by the way this one is shaft drive not belt
#5 Chris11 OFFLINE
Chris11
    old Member
  • 1730 Thanks
  • 1007 posts
Posted June 01, 2020 - 05:47 PM
the best cub to use is a 582 wide chassis throw the briggs away . you will need the bigger axles and carrier from  a newer cub like a 1440 cub get a heaving clutch and spring set up from https://vogelmanufacturing.com/
  they are the best to deal with
