Wanted
Used Kohler Command Twin Flywheel
5 replies to this topic
#1 Gabriel OFFLINE
Gabriel
  • 1453 Thanks
  • 1868 posts
Posted May 17, 2020 - 08:05 PM
Part # 2402555S.
#2 KennyP ONLINE
  • 48992 Thanks
  • 51681 posts
Posted May 18, 2020 - 04:32 AM
Took me a while to find one of those some time back. What's wrong with yours?
#3 Gabriel OFFLINE
Gabriel
  • 1453 Thanks
  • 1868 posts
Posted May 18, 2020 - 09:36 AM
I think one of the magnets on the underside has come apart (found pieces of magnet all over the top pf the engine after I took the blower housing off). I'm not sure if the alternator is charging like it should, if at all. I read on a website that magnets from a Kohler Courage SV590 would work and I have an old flywheel off of one of those but I haven't looked at it yet.
#4 EricFromPa ONLINE
EricFromPa
  • 6127 Thanks
  • 4313 posts
Posted May 18, 2020 - 04:43 PM
You can knock the magnets off another flywheel by whacking it the outside with a ball-peen hammer.
JB Weld works good to glue them back on. I glued up a set on a Kohler Command CV680 5 years ago? and it's still working fine. Wire wheel the metal until it's perfectly clean.
Magnet orientation is very important. Without the correct orientation it will not charge. You can check your magnet orientation by using a Compass.
Carefully inspect your Stator for damaged or broken windings. The magnet would of whacked it a good 1 when it came loose.
Do not use JB Quick weld. You want the Original stuff that takes a 24/48 hours to fully harden. Cover the back side of the magnet and the flywheel. The more surface area that you can cover with JB weld, the better they will hold. I even filled the gaps between the magnets with JB Weld after it set up a bit. Guaranteed they will never come off again lol.
Magnet orientation and how I glued up mine using large paper clips to hold the magnets in place while the JB Weld fully cured. Borrowed the Pics from other forums. I forget what I used as spacers to keep the magnets apart while it set up.
Edited by EricFromPa, May 18, 2020 - 04:53 PM.
  • Gabriel said thank you
#5 gears OFFLINE
gears
  • 72 Thanks
  • 52 posts
Posted May 19, 2020 - 09:04 PM
Is that the same as a Magnum18?
#6 Gabriel OFFLINE
Gabriel
  • 1453 Thanks
  • 1868 posts
Posted May 19, 2020 - 09:15 PM
I'm not sure.
