NEW! JOHN DEERE 332 GARDEN TRACTOR WHEEL WEIGHTS FRONT AND REAR SET OF 4!
7 replies to this topic
#1 John Deere 110 ONLINE
John Deere 110
  • 374 Thanks
  • 251 posts
Posted February 14, 2020 - 08:50 PM
https://www.ebay.com...GQAAOSwr~9dB6xw
I don't have a 332 and don't know if it is a good price or not.
  • Banjopicker10 said thank you
#2 James Bosma OFFLINE
James Bosma
  • 1902 Thanks
  • 878 posts
Posted February 15, 2020 - 08:35 AM
All i know about John Deere is that they are pricey
Those weights are brand new, price is about the same as buying from here
 https://www.greenpar...e=1&pageSize=24
So price is not a deal, you should be able to find a set locally for less.
Those weights will fit other tractors as long as they have 12" rear and 8" front rims
Now the fronts are harder to find, you may have to buy them new
  • John Deere 110 said thank you
#3 John Deere 110 ONLINE
John Deere 110
  • 374 Thanks
  • 251 posts
Posted February 15, 2020 - 11:43 AM
I know more a bought John Deere's then any other tractors (be cause I have had-have the most JD's)
I'll look around a littel more I want weights for my 420.
  • James Bosma said thank you
#4 James Bosma OFFLINE
James Bosma
  • 1902 Thanks
  • 878 posts
Posted February 15, 2020 - 12:04 PM
Check Kijiji or Craigslist, you may find some  used ones
I found these ones this fall for 50 whole Canadian dollars
I think they maybe John Deere but i'm not sure
So any 12" wheel weights should fit your tractor
#5 John Deere 110 ONLINE
John Deere 110
  • 374 Thanks
  • 251 posts
Posted February 15, 2020 - 12:11 PM
Those don't look like mine....They might be John Deere.
#6 Leonard VanCamp ONLINE
Leonard VanCamp
    Deere Herder
  • 1034 Thanks
  • 667 posts
Posted February 16, 2020 - 06:10 PM
Not John Deere, Bolens maybe.
#7 James Bosma OFFLINE
James Bosma
  • 1902 Thanks
  • 878 posts
Posted February 16, 2020 - 08:06 PM
After getting them i found a set on ebay that said they were John Deere and they were asking 500 for the use set, so that's what i went by, but Bolen's seem more like it
Make really don't matter to me  their wheel weights an do the same no matter who made them
Edited by James Bosma, February 16, 2020 - 08:08 PM.
  • olcowhand and Leonard VanCamp have said thanks
#8 Leonard VanCamp ONLINE
Leonard VanCamp
    Deere Herder
  • 1034 Thanks
  • 667 posts
Posted February 16, 2020 - 11:00 PM
Deere have mainly four different sets of weights the fronts like those showed in the add, a set of cast 50-55 lbs weights also like those showed in the add, plastic filled weights and finally the rear 75 lbs starter weights made for the 400.
  • 4getgto said thank you
