G&A Mini Scraper
17 replies to this topic
#1 John Deere 110 OFFLINE
John Deere 110
  • 109 Thanks
  • 53 posts
Posted February 12, 2020 - 11:08 AM
https://lewiston.cra...7052313636.html
How hard would it too be to make one of thees?
  • Cvans and Banjopicker10 have said thanks
#2 secondtry OFFLINE
secondtry
  • 3956 Thanks
  • 2488 posts
Posted February 12, 2020 - 12:18 PM
Not hard to build. Around my area it would material cost would be high enough you would have to be considering near free labor to come out even.   Don
  • Alc, KennyP, boyscout862 and 1 other said thanks
#3 John Deere 110 OFFLINE
John Deere 110
  • 109 Thanks
  • 53 posts
Posted February 12, 2020 - 02:44 PM
okay thanks I would like one.
#4 poncho62 ONLINE
poncho62
    Hangin' with the cool kids
  • 3430 Thanks
  • 2334 posts
Posted February 12, 2020 - 03:16 PM
I bet that would be real hard on your tractors drive train. I remember when I was a kid and my dad worked construction on the big ones. To load it a bulldozer had to get behind and help push it.
  • Alc, boyscout862 and John Deere 110 have said thanks
#5 John Deere 110 OFFLINE
John Deere 110
  • 109 Thanks
  • 53 posts
Posted February 12, 2020 - 03:44 PM
okay so they probably would not work?
#6 HowardsMF155 OFFLINE
  • 3056 Thanks
  • 3071 posts
Posted February 12, 2020 - 06:38 PM
Hard to say whether it would work for a small compact tractor.
We used one on the Farm I grew up on to build dams.  Surprisingly efficient since you could just keep driving the tractor round and round.
We used a Massey 265, and instead of a hydraulic tip cylinder, the bucket was retained in the cutting position by a manually operated trip lever.
It wasn't quite as wide as the tires as I recall.  Might have handled between 1 or 1.5 cubic yards.
  • John Deere 110 said thank you
#7 Leonard VanCamp OFFLINE
Leonard VanCamp
    Deere Herder
  • 859 Thanks
  • 584 posts
Posted February 12, 2020 - 08:16 PM
As long as your only moving topsoil and take shallow cuts you would be ok. Having operated the the real ones (single and twin engines), if you try to take too much at one time, you might as well go back and start all over. The full size ones have features such as locking diffs and a shift inhibit pedal. They usually have a eight speed transmission that works like a automatic.
#8 John Deere 110 OFFLINE
John Deere 110
  • 109 Thanks
  • 53 posts
Posted February 12, 2020 - 08:28 PM
okay, I was hoping too take 3-4" off at a time.
#9 Leonard VanCamp OFFLINE
Leonard VanCamp
    Deere Herder
  • 859 Thanks
  • 584 posts
Posted February 12, 2020 - 08:36 PM
In generally loose material, there is nothing faster then a scraper. 3-4 inches isn't too bad, as long as you get the right ground speed. I would start out slow and easy to see what your tractor could handle.
#10 John Deere 110 OFFLINE
John Deere 110
  • 109 Thanks
  • 53 posts
Posted February 12, 2020 - 09:55 PM
okay, I would be doing "hard" ground.
#11 Cvans OFFLINE
  • 8690 Thanks
  • 6977 posts
Posted February 13, 2020 - 12:59 AM
Not sure there is enough weight there to cut hard ground. May want to run a digger or disc over it first.
  • Leonard VanCamp said thank you
#12 boyscout862 ONLINE
  • 14463 Thanks
  • 9729 posts
Posted February 13, 2020 - 11:07 AM
You should look for an Earthcavator. I have one for behind my Simplicity 3310 and it works well for levelling out the driveway after mudseason. There are videoes on youtube of Earthcavators in use. Good Luck, Rick
  • Cvans said thank you
#13 John Deere 110 OFFLINE
John Deere 110
  • 109 Thanks
  • 53 posts
Posted February 13, 2020 - 11:18 AM
Okay my biggest problem is I have 1 tiller and that is all the attachments I have for the Garden Tractors I own...
#14 KennyP ONLINE
  • 47693 Thanks
  • 51084 posts
Posted February 13, 2020 - 01:39 PM
How many have a 3-point hitch? Sleeve hitch? That will help us help you!
#15 John Deere 110 OFFLINE
John Deere 110
  • 109 Thanks
  • 53 posts
Posted February 13, 2020 - 08:19 PM
my only one with a 3 point is my 420 and I do not have a sleeve hitch. (I for got I have a rear grooming mower 260 for my 420)
