Theme Font Size Changer
10 replies to this topic
#1 chieffan ONLINE
  • 14486 Thanks
  • 8488 posts
Posted February 08, 2020 - 11:44 AM
For FireFox.  Anyone have a new version that works with the newer FireFox?  Small print in the upper left corner as well as the Bookmarks is getting hard to read. This addon is supposed to do that but it says it won't work with the newer version of FireFox.  Got to be one out there some place.
#2 ducky OFFLINE
  • 2204 Thanks
  • 4229 posts
Posted February 08, 2020 - 12:55 PM
Do This.
hold "Ctl" key and tap the "+" key and make as big as you like.
  • Cvans, LilysDad and chieffan have said thanks
#3 chieffan ONLINE
  • 14486 Thanks
  • 8488 posts
Posted February 08, 2020 - 04:12 PM
That works for web pages but not for the FireFox text.Have used that on web pages for some time now.
#4 KennyP ONLINE
  • 47622 Thanks
  • 51061 posts
Posted February 08, 2020 - 05:05 PM
Go to the General tab of FF and you can change it there!
  • ducky and chieffan have said thanks
#5 chieffan ONLINE
  • 14486 Thanks
  • 8488 posts
Posted February 08, 2020 - 06:12 PM
Where do I find the General tab ?  Mine has File, Edit, View, History, Bookmarks, Tools, Help.  Nothing in any of them that I found to change the FF text size.  Been looking for this answer for a few weeks now with no luck.
#6 KennyP ONLINE
  • 47622 Thanks
  • 51061 posts
Posted February 08, 2020 - 06:25 PM
Usually FF has a way to change settings. What system are you on? Win 10 or ?   Normally at the far right of where you enter a web address is 3 horizontal lines. That's where you change FF settings! If all else fails, go to FF web page, you find an answer there!
#7 chieffan ONLINE
  • 14486 Thanks
  • 8488 posts
Posted February 08, 2020 - 07:53 PM
On W 10-.  Been to that side panel and that is where it came up that it no longer works on the newer version of FF.  Can change text color and background color is all.  Don't do nothing with text size.  Need an add on  "Theme  Font Size Changer" that will work with the newer version of FF.
#8 chieffan ONLINE
  • 14486 Thanks
  • 8488 posts
Posted February 08, 2020 - 09:17 PM
Finally got it.  Found some information that uses the about:config in FireFox.  Thanks for the help guys.  You was right Kenny.  Buried in FF itself.
#9 chieffan ONLINE
  • 14486 Thanks
  • 8488 posts
Posted February 09, 2020 - 09:46 AM
Got it taken care of.  Use a new tab, in the URL search line enter:   about:config   press enter.  Search down the long list for:
layout.css.devPixelsPerPx
Click on the pencil and a number will appear in the long box.  1 is the default.  Increase that number to 1.2 and see if you like it.  Adjust accordingly but stay well below 4.  Web page can be adjusted from there.
No grantee this will work for everyone but it did for me.
  • secondtry said thank you
#10 secondtry ONLINE
secondtry
  • 3945 Thanks
  • 2486 posts
Posted February 09, 2020 - 10:41 AM
layout.css.devPixelsPerPx   How in the world did you make any sense out of that.    Don
  • chieffan said thank you
#11 chieffan ONLINE
  • 14486 Thanks
  • 8488 posts
Posted February 09, 2020 - 01:38 PM
I didn't.  Just what the instructions said to look for.  It worked but still don't make a bit of sense, but that's not unusual for me.
