Wanted
Front rims for Pennsylvania meteor 1010
pennsylvania meteor panzer front rims
2 replies to this topic
#1 NATE_HM523 OFFLINE
NATE_HM523
  • 15 Thanks
  • 21 posts
Posted February 07, 2020 - 07:52 PM
I'm in search of one or a pair of front rims for a Pennsylvania meteor 1010.
#2 EricFromPa ONLINE
EricFromPa
    Fixer of Broken junk
  • 6872 Thanks
  • 4606 posts
Posted February 08, 2020 - 10:35 AM
Parts manual.
http://www.panzertra... parts list.pdf
Original tire size is 15x6.00x6 which is a very common sized tire and rim for a newer Lawn tractor if you can not find a set with the 2 piece Timkin bearings. Shaft size should be .75" or 3/4" which is a little more uncommon as most of the newer tractors with a 6" front tire use a smaller 5/8" hub.
The Panzers used a bushing type wheel that is the same size but the Meteor had 2 piece timkin bearings. It will be pretty hard to find a set of original Meteor rims.
Some WheelHorse (200 series) and JohnDeere LTs had a 3/4" front axle with the same size tire if you can't find any thing else. They had a Bushing type rim. It will work but you won't be able to attach a grease cap like the original rims had.
Edited by EricFromPa, February 08, 2020 - 12:29 PM.
#3 NATE_HM523 OFFLINE
NATE_HM523
  • 15 Thanks
  • 21 posts
Posted February 08, 2020 - 07:45 PM
Thanks for the info, at least I have some ideas if I can't locate the original style rims.
Also tagged with one or more of these keywords: wanted, pennsylvania, meteor, panzer, front rims
