REVOLT tractors
13 replies to this topic
#1 Mudrig150 ONLINE
Mudrig150
  • 447 Thanks
  • 447 posts
Posted January 16, 2020 - 01:05 PM
Here's my thread for all the Revolt tractor designs I make. These are all original designs, made by me.
Here's the F-1925, part of the Revolt F-series, which was produced from 1963-1974. It features a water cooled 6 cylinder diesel, which produces 125 horsepower, and is hooked to a Dual range hydrostatic transmission. It puts out 94 horsepower at the drawbar and 106 at the PTO. It has a top speed of 19 MPH (full throttle, full forward on hydro, high range). Its equipped with 4WD.
Second picture is the tractor in the prototype "White stripe" FA1925 color scheme.
  • Alc, hamman, Mark 149 J. and 3 others have said thanks
#2 Mudrig150 ONLINE
Mudrig150
  • 447 Thanks
  • 447 posts
Posted January 31, 2020 - 08:47 AM
The Series 2 hood. Based on a combination of Bolens, Cub Cadet, and a couple other brands.
  • Alc, IHCubCadet147 and John Deere 110 have said thanks
#3 Mudrig150 ONLINE
Mudrig150
  • 447 Thanks
  • 447 posts
Posted February 21, 2020 - 08:20 AM
I'm taking design suggestions for the next model... What design features should I put in the FA15, 17, and 19? They are all series so they will be similar. 1951-1963, so keep it in that time range.
  • John Deere 110 said thank you
#4 CraftsmanGT OFFLINE
CraftsmanGT
  • 361 Thanks
  • 319 posts
Posted February 22, 2020 - 03:38 AM
Why not do something American, instead of some foreign junk?
#5 John Deere 110 OFFLINE
John Deere 110
  • 137 Thanks
  • 72 posts
Posted February 22, 2020 - 12:09 PM
Why not make one without a cab?
#6 Mudrig150 ONLINE
Mudrig150
  • 447 Thanks
  • 447 posts
Posted February 24, 2020 - 09:16 AM
What? It's a fictional tractor. I'm designing it myself. It's based off american tractors, mainly.
#7 Mudrig150 ONLINE
Mudrig150
  • 447 Thanks
  • 447 posts
Posted February 25, 2020 - 02:10 PM
It's a stroker, the FA19...
#8 John Deere 110 OFFLINE
John Deere 110
  • 137 Thanks
  • 72 posts
Posted February 25, 2020 - 04:27 PM
Looks Good, you could make a row crop!!
#9 Mudrig150 ONLINE
Mudrig150
  • 447 Thanks
  • 447 posts
Posted February 26, 2020 - 08:46 AM
The FA19 (Farm and Agriculture 19) is basically a crawler tractor with wheels. The FC19 is the crawler version, which is the main design. The FA19 has a bore and stroke of 6 inches by 9 inches, so it's a 12.5 liter 3 cylinder diesel. The engine is huge, it's 24 inches long, 22.5 inches wide, and 40.5 inches tall.
#10 Mudrig150 ONLINE
Mudrig150
  • 447 Thanks
  • 447 posts
Posted March 04, 2020 - 08:52 AM
Well, there's the reason my tractor is so small. Basing the scale of the tractor on the engine... On the left, a Magnum model made to actual Magnum dimensions, and on the right, the engine I was using. Notice the size difference. THAT would explain the tractor's strange size issue.
#11 Mudrig150 ONLINE
Mudrig150
  • 447 Thanks
  • 447 posts
Posted March 11, 2020 - 11:24 AM
Here it is, the FA19. The FA19 crawler is still in the works but I think it's pretty solid.
Revolt FA19
Engine HP         5
No. of Cylinders          3
Bore X Stroke          6 x 9 Inches
Maximum Operating RPM         850
Dry Weight         5,167 Pounds
Fuel Capacity         37.4 Gallons
Top Speed         2 MPH (Gear 1)         5 MPH (Gear 2)         10 MPH (Gear 3)         -2 MPH (Reverse)
Maximum drawbar pull*         10,561 Pounds
3 point hitch         Category 1
Rear PTO         540 RPM
*Gear 1, 700 RPM with 5,000 lbs of ballast
#12 John Deere 110 OFFLINE
John Deere 110
  • 137 Thanks
  • 72 posts
Posted March 11, 2020 - 12:02 PM
could you put a HI LO on it so it has a better road speed?
#13 Mudrig150 ONLINE
Mudrig150
  • 447 Thanks
  • 447 posts
Posted March 11, 2020 - 12:48 PM
The Dual range-box is an option. It goes a bit faster with the range-box, 16 MPH.
#14 John Deere 110 OFFLINE
John Deere 110
  • 137 Thanks
  • 72 posts
Posted March 11, 2020 - 10:07 PM
okay.
