A Welcome Surprise
kubota repower genset
11 replies to this topic
#1 Utah Smitty OFFLINE
Utah Smitty
  • 2307 Thanks
  • 2003 posts
Posted January 07, 2020 - 11:31 PM
When I started moving things to my shop I put them on pallets and crates, then covered them all with tarps since I didn't have a dried in roof, yet.
I was moving things around today so the electrician can install lighting on the east side of the shop and I came upon this:
It must not have been on the trailer that was stolen after all...
Smitty
  • 101 senior, KennyP, boyscout862 and 8 others have said thanks
#2 kjmweld ONLINE
kjmweld
  • 3541 Thanks
  • 1309 posts
Posted January 08, 2020 - 12:18 AM
Wow, that's very fortunate albeit still a hard loss on the trailer. That's a big "hell yeah" tho. Glad you still have it. 👍
  • KennyP, Utah Smitty, Mark 149 J. and 1 other said thanks
#3 KennyP ONLINE
  • 52022 Thanks
  • 52958 posts
Posted January 08, 2020 - 04:30 AM
Glad you found that diesel!
  • Utah Smitty, Mark 149 J. and Banjopicker10 have said thanks
#4 Utah Smitty OFFLINE
Utah Smitty
  • 2307 Thanks
  • 2003 posts
Posted January 08, 2020 - 09:02 PM
i got to checking and I discovered the engine is set up to run at 1,800 rpm... :wallbanging:
This won't work in my Bolens or Dayton--they're both hydrostats.  I wonder if it would work in my Case 444?  It only puts out about 10-12 hp at that speed, so the hp shouldn't overwhelm the Case pump.
Has anyone repowered a Case 444 with a diesel??
Smitty
  • 4getgto and Banjopicker10 have said thanks
#5 Cvans ONLINE
  • 9520 Thanks
  • 7279 posts
Posted January 08, 2020 - 09:21 PM
Get it running before you start feeling bad. It's very possible that you'll be able to throttle it. I have yet to come across one that couldn't be. I
I've had several of them that were governed and simply removed the throttle positioning solenoid and they worked just fine. The others  had a plain throttle stop that could be adjusted or removed.
Hopefully you won't prove me wrong.
  • KennyP, 4getgto and Banjopicker10 have said thanks
#6 Cvans ONLINE
  • 9520 Thanks
  • 7279 posts
Posted January 08, 2020 - 09:22 PM
What's your plans for the generator?
  • Banjopicker10 said thank you
#7 tractorskipper OFFLINE
tractorskipper
  • 1194 Thanks
  • 718 posts
Posted January 08, 2020 - 11:10 PM
That would be sweet on a Case I would think.
  • Utah Smitty and Banjopicker10 have said thanks
#8 Utah Smitty OFFLINE
Utah Smitty
  • 2307 Thanks
  • 2003 posts
Posted January 08, 2020 - 11:30 PM
I started her up when I first got her... once I purged the injector lines she started fine and ran smooth. I'll have to check out the throttle stop on her.
Smitty
  • KennyP, Cvans, 4getgto and 1 other said thanks
#9 Utah Smitty OFFLINE
Utah Smitty
  • 2307 Thanks
  • 2003 posts
Posted January 08, 2020 - 11:33 PM
I don't know if the generator works or not.  It had been either on an RV or as an APU for a truck and the area inside the electrical box had a lot of corrosion.  The start switch wire had corroded through, which may be why it was scrapped.
I'm a little torn... it's only 4kw, but would run forever.  I already have an Onan 10kw diesel genset, so this one may end up on one of my GTs...
Smitty
  • KennyP, Cvans, 4getgto and 2 others have said thanks
#10 4getgto ONLINE
4getgto
  • 6042 Thanks
  • 2222 posts
Posted January 09, 2020 - 05:48 AM
Sweet little 3 cylinder motor. So the motor is actually an Onan diesel motor or just the genstator head.?
I'm unfamiliar with these.
Edited by 4getgto, January 09, 2020 - 05:48 AM.
  • Cvans and Banjopicker10 have said thanks
#11 Utah Smitty OFFLINE
Utah Smitty
  • 2307 Thanks
  • 2003 posts
Posted January 09, 2020 - 06:31 AM
The specs list it as an Onan engine, but it's made by Kubota.
Smitty
#12 4getgto ONLINE
4getgto
  • 6042 Thanks
  • 2222 posts
Posted January 09, 2020 - 08:12 AM
Smitty
Also tagged with one or more of these keywords: kubota, repower, genset
