* * * - - 1 votes
Smoke out carb
24 replies to this topic
#1 Mudrig150 OFFLINE
Mudrig150
  • 453 Thanks
  • 456 posts
Posted January 07, 2020 - 01:37 PM
So, on my 140 with K241, I was trying to start it up after fixing the fuel system, and now, instead of getting nothing, I get smoke out the carb. It started as white smoke out the exhaust (which I expected, with the glazed cylinder) but after a few pops all the smoke quickly stopped coming out the exhaust and only comes out the carb now. I'm thinking some carbon came from the cylinder and maybe scratched the valve seat, so I've got a valve lapping kit coming. Think that is the problem?
Here's a video:
https://www.youtube....h?v=9LER0R_ISq4
  • chieffan and Banjopicker10 have said thanks
#2 poncho62 ONLINE
poncho62
    Hangin' with the cool kids
  • 3640 Thanks
  • 2409 posts
Posted January 07, 2020 - 02:59 PM
Is that when it's running or just trying to start?
It may be fuel shooting back out of carb,
#3 Mudrig150 OFFLINE
Mudrig150
  • 453 Thanks
  • 456 posts
Posted January 08, 2020 - 08:42 AM
Trying to start. Doesn't start because of how bad the compression loss is.
  • Banjopicker10 said thank you
#4 poncho62 ONLINE
poncho62
  • 3640 Thanks
  • 2409 posts
Posted January 08, 2020 - 01:26 PM
I am thinking then the intake valve is stuck open, gas is drawn in, valve stays open, so instead of compressing the gas, it shoots right back out the open valve again.
  • LilysDad and Banjopicker10 have said thanks
#5 Mudrig150 OFFLINE
Mudrig150
  • 453 Thanks
  • 456 posts
Posted January 08, 2020 - 03:12 PM
They open and close fine. It builds compression, so it wouldn't a stuck valve. It just shoots all the compression out the intake when trying to start.
Edited by Mudrig150, January 08, 2020 - 03:13 PM.
#6 lyall OFFLINE
lyall
  • 2459 Thanks
  • 1722 posts
Posted January 08, 2020 - 05:53 PM
have you tried removing the muffler and trying it?
a blocked muffler could cause it to blow back thru the carb
Edited by lyall, January 08, 2020 - 05:53 PM.
#7 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 17265 Thanks
  • 11453 posts
Posted January 08, 2020 - 06:14 PM
That doesn't make sense. How can it build compression and yet blow it out the intake? Unless it's out of time.
#8 ducky OFFLINE
  • 2291 Thanks
  • 4287 posts
Posted January 08, 2020 - 06:29 PM
That is my thought. TIMING.
  • KennyP and Banjopicker10 have said thanks
#9 Utah Smitty OFFLINE
Utah Smitty
  • 2300 Thanks
  • 2001 posts
Posted January 08, 2020 - 07:09 PM
If the valve is burned or not seating will it could build some compression, but blow smoke back through the car since the ignited fuel has more pressure than the compressed air.
Just thinkin'
Smitty
  • ducky, 4getgto and Banjopicker10 have said thanks
#10 secondtry OFFLINE
secondtry
  • 4284 Thanks
  • 2624 posts
Posted January 08, 2020 - 07:24 PM
I am thinking the 241 has a blow by tube from the crank case to the air cleaner. Can't see in the vidio if the smoke is coming from the carb or the blow by.   Don
  • 4getgto and Banjopicker10 have said thanks
#11 Mudrig150 OFFLINE
Mudrig150
  • 453 Thanks
  • 456 posts
Posted January 09, 2020 - 08:55 AM
Carb. Fully out the intake, none out the breather.
  • secondtry and Banjopicker10 have said thanks
#12 Mudrig150 OFFLINE
Mudrig150
  • 453 Thanks
  • 456 posts
Posted January 09, 2020 - 08:56 AM
The muffler has fine flow, worked fine before.
Just thinkin'
Smitty
It builds barely enough compression to fire, but then the increase in pressure from combustion shoots the compression out the intake.
#13 Banjopicker10 OFFLINE
Banjopicker10
  • 518 Thanks
  • 313 posts
Posted January 09, 2020 - 01:14 PM
I have a speedex 1040 that does the same thing
#14 dodge trucker OFFLINE
dodge trucker
  • 3722 Thanks
  • 4393 posts
Posted January 09, 2020 - 01:38 PM
I had my cub 129 doing the same thing last weekend. The starter generator would barely spin it, it would fire and spin 1/2 a turn backwards so the charge would go in thru the intake and back out thru the intake.
#15 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 17265 Thanks
  • 11453 posts
Posted January 10, 2020 - 07:45 AM
Wait! When you say carb, do you mean an engine part . . .        or drug paraphernalia?
  • AllisKidD21 and Banjopicker10 have said thanks
