Cub Cadet 265 Snow Blower
265 snow blower
5 replies to this topic
#1 handdsaw OFFLINE
handdsaw
  • 1 Thanks
  • 7 posts
Posted November 29, 2019 - 09:16 PM
Not sure if this is the correct forum--  We have an old '74 or so Cub Cadet # 265 26" Snow Blower.  I understand these were built by Ariens, along the lines of their 10000 series units.
  Looking for some insight to getting the blower shaft out.  The cast clutch engagement sliding dog on the blower shaft input is frozen on the splined drive (fan and gearbox) shaft.  We used penetrating oil, put heat to it, and tried tapping and prying at the same time.  Doesn't budge.  Really -- this is not my first time "mechanic-ing"  just want to error on the side of someone else's experience when dealing with non-findable parts!!
  Hate to put a puller on it and break it.....Anybody got any experience with these as to how sturdy the casting is?  Would like to put a puller on it with heat, and some physical encouragement  but don't want to break it.
  Thanks!
  • 4getgto said thank you
#2 Cubcadetsouthdakota ONLINE
Cubcadetsouthdakota
  • 347 Thanks
  • 253 posts
Posted November 29, 2019 - 10:47 PM
What kinda blower is this? Does it actually say cub cadet ??? I assume this is a lawn tractor your using ?
#3 KennyP ONLINE
  • 49401 Thanks
  • 51898 posts
Posted November 30, 2019 - 06:58 AM
Sounds like a walk-behind blower, but not sure.
  • Cubcadetsouthdakota and 4getgto have said thanks
#4 Kyocum OFFLINE
Kyocum
  • 331 Thanks
  • 454 posts
Posted November 30, 2019 - 07:17 AM
I have always had good luck using a torch to heat it up not quite red hot and pouring cold water over it. The thermal shock usually will break up the rust binding it together. Once it is cool give it a shot of penetrating oil. I myself use kroil. It is by far the best penetrating oil on the market. Good luck.
Edited by Kyocum, November 30, 2019 - 07:19 AM.
  • KennyP and 4getgto have said thanks
#5 Kyocum OFFLINE
Kyocum
  • 331 Thanks
  • 454 posts
Posted November 30, 2019 - 07:24 AM
He is dealing with a walk behind blower. CC never made a model 265 blower attachment.
Edited by Kyocum, November 30, 2019 - 07:24 AM.
  • KennyP, Cubcadetsouthdakota and 4getgto have said thanks
#6 handdsaw OFFLINE
handdsaw
  • 1 Thanks
  • 7 posts
Posted November 30, 2019 - 08:39 AM
Good Morning,   Thanks for the replies.  Yes, it is a walk-behind.
  Appreciate the tip on the cold water shock.  Kroil seems to work the best of different products I've used over the years.  Heating with a hand-held torch on MAP gas, hope I can get enough heat into it before the shaft gets real hot too.
Also tagged with one or more of these keywords: 265, snow blower
