Joining the Orange Crowd with my new purchase
case ingersoll garden tractor
36 replies to this topic
#16 MNGB ONLINE
MNGB
  • 4874 Thanks
  • 2431 posts
Posted October 31, 2019 - 12:55 PM
Hi Kster526, good deal on the 224 got got it looking great shined up real nice and the new seat really makes it look good
  • Kster526 said thank you
#17 Kster526 ONLINE
Kster526
  • 2055 Thanks
  • 1048 posts
Posted October 31, 2019 - 04:57 PM
Thank u sir got a little more work done.
Painted the rims,front grill ,auger and the interior of the snow caster
New tires on the rims . Front ones blew up easily the backs not do much
Will probably end up putting tubes in .
Enjoy watching what ur up to on yours also please keep the pics coming
The Case has really found a spot in my heart .
Really cannot wait to try it out this Winter
Edited by Kster526, October 31, 2019 - 05:26 PM.
  • jhn9840, KennyP, MNGB and 3 others have said thanks
#18 KennyP ONLINE
  • 49392 Thanks
  • 51889 posts
Posted October 31, 2019 - 05:10 PM
Love to own a Case, but they are more than JD's down here. And a lot harder to find!
  • MNGB, Kster526 and 4getgto have said thanks
#19 Kster526 ONLINE
Kster526
  • 2055 Thanks
  • 1048 posts
Posted October 31, 2019 - 05:29 PM
Only the second one around here I have come across.
Still not sure were to find Case specific parts if I break something
Around here it’s green ,yellow and white .
  • KennyP and MNGB have said thanks
#20 Kster526 ONLINE
Kster526
  • 2055 Thanks
  • 1048 posts
Posted November 03, 2019 - 05:18 PM
Finally got the back tires mounted,
even with tubes couldn’t get them to mount up easily.
Tied a strap around them again and broke three
different ones before the beads finally popped into place.
Mounted up the tire chains
now to figure out how I want to add the weights.
I’m sure that’ll be easier than mounting up those [email protected]& tires!
  • KennyP, gopher and MNGB have said thanks
#21 iko ONLINE
iko
  • 1 Thanks
  • 1 posts
Posted November 07, 2019 - 11:41 PM
When the tire's edge is far from the edge of the rim so it can't be pumped, I've used this trick. Tie a ratcheting strap along the tire right down the middle and tighten it. This forces the sides of the tire against the rim enough for a seal to happen. Then start pumping air in. When enough carefully undo the strap ratchet. One has to be really careful as it tends to slap back hard. I changed my rear tires on the 220 and a rear motorcycle tire this way.
  • MNGB said thank you
#22 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 17481 Thanks
  • 11533 posts
Posted November 08, 2019 - 06:50 AM
But they are a lifetime purchase . . .
I know of three mail order Case/ Ingersoll dealers who give great service.
There is also a trick I haven't personally used yet, but others have sworn by.You spray starting fluid inside the tire and rim, light it, and the resulting explosion seats the bead. Yeah, I know! OSHA doesn't like it.
Edited by LilysDad, November 08, 2019 - 06:55 AM.
  • MNGB, Leonard VanCamp and 4getgto have said thanks
#23 4getgto ONLINE
4getgto
  • 4326 Thanks
  • 1796 posts
Posted November 08, 2019 - 07:25 AM
I've done that too many times with truck tires.
One more tip to that method is to clip on a air chuck and push air in as you're doing it. Otherwise it can seat and then back off if you don't. And no it doesn't blow all the ether out if you do it quick enough. Another tip is to also "spray a fuse" with the ether away from the tire about 5+ feet and light it up... That way you're not standing over it. Remember we have to be SAFE. 😉
I've seen truck tires jump off the ground if too much ether is sprayed in...!
  • LilysDad, MNGB and Leonard VanCamp have said thanks
#24 Kster526 ONLINE
Kster526
  • 2055 Thanks
  • 1048 posts
Posted November 08, 2019 - 08:32 AM
COULD YOU PLEASE SHARE THE CASE MAIL ORDER THAT YOU KNOW OF I WOULD GREATLY APPRECIATE IT.
JUST NOT INTO THE LIGHTING STARTING FLUID TO DO THAT. HOUSE IS PAYED FOR AND AM VERY FOND OF ALL MY FINGERS AND TOES!!!! :firejumper:
  • LilysDad and MNGB have said thanks
#25 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 17481 Thanks
  • 11533 posts
Posted November 08, 2019 - 09:01 AM
This is the one I use the most. They are also very good at giving help with problems. https://salempwr.com...tore/ingersoll/
#26 Kster526 ONLINE
Kster526
  • 2055 Thanks
  • 1048 posts
Posted November 09, 2019 - 03:54 PM
Thank you very much for the info
Well today she got her weights mounted.
A piece of 3x4x1/4 angle bolted to the frame using
the factory half inch bolts on the back of her.
Bought 2 more suitcase weights and added a rear light
Pretty happy with the results. Wish I would have thought
of this first before trying the wheel weight and scratching up
the newly painted rims. O well spring touch up.
She’s now ready to do battle with Ma Nature
  • KennyP, LilysDad, MNGB and 2 others have said thanks
#27 KennyP ONLINE
  • 49392 Thanks
  • 51889 posts
Posted November 09, 2019 - 04:28 PM
GREEN WEIGHTS? Does not go well with the Orange!!
  • MNGB, Kster526 and IHCubCadet147 have said thanks
#28 Kster526 ONLINE
Kster526
  • 2055 Thanks
  • 1048 posts
Posted November 09, 2019 - 05:34 PM
I knew I would here about that!!!!LOL
  • KennyP, MNGB and Leonard VanCamp have said thanks
#29 KennyP ONLINE
  • 49392 Thanks
  • 51889 posts
Posted November 09, 2019 - 05:45 PM
Just send them to me! I have some green down here they will fit on!
  • MNGB and Kster526 have said thanks
#30 mac102004 ONLINE
mac102004
  • 593 Thanks
  • 608 posts
Posted November 09, 2019 - 08:03 PM
Salem Power is good for parts, they have parts diagrams linked on their site. I also use Case Ingersoll Parts a lot, Jason is the guys name. Great service. www.caseingersollparts.com
Also tagged with one or more of these keywords: case, ingersoll, garden tractor
