Winter project
200 replies to this topic
#196 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 5296 Thanks
  • 2112 posts
Posted May 26, 2020 - 03:56 PM
The sprockets are lined up and the frame is marked where the mounting holes for the pillow block bearings will go.
The mounting holes are drilled and threaded into the frame.
Both of the bearings are bolted in place.
The jack shaft is slid into the bearings and the sprocket is set back on the shaft.
I haven't cut the keyway for the sprocket into the end of the shaft yet.
After I get the sprocket on the other end set up and the shaft cut off to the correct length, then I'll cut the keyways in both ends.
  • jhn9840, KennyP, Leonard VanCamp and 4 others have said thanks
#197 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 5296 Thanks
  • 2112 posts
Posted May 27, 2020 - 12:03 PM
The #50 chain and tension sprocket are mounted on the tractor.
Now I'm waiting on parts to complete the final drive on the other side.
  • jhn9840, KennyP, LilysDad and 6 others have said thanks
#198 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 5296 Thanks
  • 2112 posts
Posted May 28, 2020 - 11:56 AM
This is the new sprocket for the detachable chain.
I fit a hub to it and welded it on one side.
The sprocket is slid onto the jack shaft and then the jack shaft is cut off a little ways past it.
The jack shaft is set up in the mill so I can cut the keyways into it.
The fit of the key is first checked.
And the fit of the sprocket is checked before I un-clamp the jack shaft and turn it around to machine the other keyway.
The jack shaft is re-assembled on the tractor and the chains are put on the sprockets.
  • jhn9840, KennyP, 29 Chev and 3 others have said thanks
#199 KennyP ONLINE
  • 48993 Thanks
  • 51684 posts
Posted May 28, 2020 - 12:17 PM
Looks real good, hope it slows it down enough.
  • jdcrawler said thank you
#200 DougT ONLINE
DougT
    Dog Approved
  • 8255 Thanks
  • 5673 posts
Posted May 28, 2020 - 12:32 PM
Never noticed the drive chain was detachable before. That wasn't a Centaur part. They had an odd size roller chain.
#201 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 5296 Thanks
  • 2112 posts
Posted May 28, 2020 - 01:36 PM
That detachable farm chain was the only thing that I could find locally that fit the Centaur sprockets.
Edited by jdcrawler, May 28, 2020 - 01:38 PM.
  • DougT and KennyP have said thanks
