Economy Jim Dandy diesel?
#1
OFFLINE
Posted July 21, 2019 - 09:37 PM
- Achto said thank you
#2
OFFLINE
Posted July 22, 2019 - 10:43 PM
I put a 10hp Hatz diesel in my Wheel Horse. It was a fun project, I had to raise the hood & the dash 3" to fit it into the short frame tractor but it was well worth it. This thing has all the power I could ever want & I put 10hrs on with 1.5 gal of fuel.
I had a belt drive to deal with, which is a little easier than the automotive style clutch in an Economy. You may have to make your own engine to bell housing adapter.
Edited by Achto, July 22, 2019 - 10:44 PM.
- Alc said thank you
#3
OFFLINE
Posted July 23, 2019 - 04:43 AM
Like what Achto said about the engine to bellhousing problem being the biggest . I think the flywheel has enough metal if you needed to have a bigger crankshaft . The engine mounts are just angle iron bolted to the C channel frame so I wouldn't think mounts would be a big issue
- Achto and jtkerr98 have said thanks
