Ek-10
transmission
4 replies to this topic
#1 DenBar1 OFFLINE
DenBar1
  • 2 Thanks
  • 11 posts
Posted May 25, 2019 - 06:04 PM
Hello everyone.  I bought a EK-10, got it running.  When I try to shift into gear it grinds a little and doesn't move in any gear.  High speed matched set belts are installed.  Any help would be greatly appreciated.
#2 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 10214 Thanks
  • 5240 posts
Posted May 25, 2019 - 10:19 PM
There is a freewheel ratchet inside the left [I think] rear wheel.  Make sure the 1/2 circle rod is out and not pushed in. It is spring loaded and should pop out when released.   If you can push the tractor [for lack of a better term] that is in neutral.  These tranny's grind if you aren't completely stopped and the drive belt adjusted to where the tranny input pulley is not turning when the clutch is down.
Edited by Gtractor, May 25, 2019 - 10:20 PM.
  • MailmAn, logmillingman and DenBar1 have said thanks
#3 Bolens 1000 OFFLINE
  • 17310 Thanks
  • 18799 posts
Posted May 26, 2019 - 07:33 PM
As Kris mentioned there is a free wheel handle that may not be engaged, the full owners manual is uploaded on the site here which shows how to turn it .
As for the grinding there is an adjustment on the clutch petal end for the cable as the brake shoe wears , or it means its time to replace the brake shoe if your still grinding
  • Bruce Dorsi, logmillingman and DenBar1 have said thanks
#4 DenBar1 OFFLINE
DenBar1
  • 2 Thanks
  • 11 posts
Posted May 30, 2019 - 11:16 AM
Figured out the driving issue. Took the assembly apart cleaned and painted it, works smooth now.  It was the brake pad, I have replaced that also but it doesn't seem to hit the two pully's.  I've adjusted the cable.  Have to look into it more to see if there is something hitting somewhere that is preventing the shoe from making contact.
  • logmillingman said thank you
#5 Bolens 1000 OFFLINE
  • 17310 Thanks
  • 18799 posts
Posted May 30, 2019 - 04:25 PM
Check the cable routing
Also tagged with one or more of these keywords: transmission
