Belt Problem, John Deere D170 54 inch deck
20 replies to this topic
#16 bear15 OFFLINE
bear15
  • 7 Thanks
  • 59 posts
Posted June 27, 2018 - 07:52 AM
Got it.
My thought on this is as the blades are put under load of the heavier grass the spindle is allowing enough movement of the pulley to throw the belt. So checking for any movement of the spindle through the rotation could be the problem. Checking using the blades will give the leverage. So if the bearing even have one spot that is worn enough it would throw the belt. Pushing on one end of the blade towards the deck as it is rotated may find problem. Good luck finding what is causing this.
Charlie
#17 bear15 OFFLINE
bear15
  • 7 Thanks
  • 59 posts
Posted June 27, 2018 - 07:53 AM
I will need to double check this.
Did it always throw the belt for you ?   Is there any adjustments to the deck front to back ? Maybe you could move the deck back further . When the belt come off does it give you any clues on where the problem might be , I would think the motor side would have a belt guard around the clutch that won't let it come off there
  • danniel said thank you
#18 bear15 OFFLINE
bear15
  • 7 Thanks
  • 59 posts
Posted June 28, 2018 - 07:35 PM
Thanks for ALL the help. I completed the following and it seemed to fix the belt throwing problem.
-replaced all 3 spindles
-replaced all 3 idler wheels
-replaced all 3 blades
-tightened the idler plate 3/4 of a turn
-set the front of the deck 1/2" higher than the back
-set the cutting depth 1 notch below 3
-kept in idle speed when engaging blades
-cleaned all debris from deck area
#19 Alc OFFLINE
  • 9061 Thanks
  • 8311 posts
Posted June 29, 2018 - 05:25 AM
Glad everything is working well again
#20 danniel OFFLINE
danniel
  • 3 posts
Posted January 10, 2021 - 05:34 PM
Thanks for ALL the help.I completed the following and it seemed to fix the belt throwing problem.
-replaced all 3 spindles.
-replaced all 3 idler wheels.
-replaced all 3 blades.
-tightened the idler plate 3/4 of a turn.
-set the front of the deck 1/2" higher than the back.
-set the cutting depth 1 notch below 3.
-kept in idle speed when engaging blades.
I have JD LX277. in the same way, I reattached all the knives, but I didn't get much results.
Edited by danniel, January 10, 2021 - 05:38 PM.
#21 KennyP ONLINE
  • 52016 Thanks
  • 52955 posts
Posted January 10, 2021 - 05:54 PM
Has the belt tension spring gone lax?
