1988 John Deere 318 Repower with 20HP Vanguard V-Twin 351447-1075A1 Revival
311 replies to this topic
#301 Trav1s ONLINE
Trav1s
  • 3987 Thanks
  • 4854 posts
Posted March 28, 2020 - 02:29 PM
Today’s work included installing the firewall, finishing the fuel system, and getting ready for wiring. Need a spacer to raise the air cleaner assembly up to clear the fuel pump too.
Fuel pump is mounted using firewall bolts so that was an easy install.  I will be installing a 90 degree fitting on the output side of the pump.
Edited by Trav1s, March 28, 2020 - 05:28 PM.
  • KennyP, Mark 149 J. and IHCubCadet147 have said thanks
#302 KennyP ONLINE
  • 48998 Thanks
  • 51684 posts
Posted March 28, 2020 - 05:21 PM
Glad it's coming together for you, Travis!
#303 Trav1s ONLINE
Trav1s
  • 3987 Thanks
  • 4854 posts
Posted March 28, 2020 - 06:00 PM
2019 went down in the books as one it love to forget. Got a new job that has been going very well only to loose hours due to the current mess. I got the time to do it and the remaining parts list was small and cheap so now is the time.
  • KennyP and Mark 149 J. have said thanks
#304 KennyP ONLINE
  • 48998 Thanks
  • 51684 posts
Posted March 28, 2020 - 06:17 PM
I understand that! I have a bunch of unfinished projects going right now. Just no $ to finish.
#305 Trav1s ONLINE
Trav1s
  • 3987 Thanks
  • 4854 posts
Posted March 28, 2020 - 08:10 PM
After this is done I will get back to the 312...
#306 Trav1s ONLINE
Trav1s
  • 3987 Thanks
  • 4854 posts
Posted April 01, 2020 - 06:17 PM
Worked on the muffler heatshield using some aluminum sheet scrap I stashed in the garage. It will need cut to fit but that’s no big deal and then will get painted in JD Muffler Black paint.
Edited by Trav1s, April 01, 2020 - 06:30 PM.
#307 Trav1s ONLINE
Trav1s
  • 3987 Thanks
  • 4854 posts
Posted April 02, 2020 - 03:35 PM
Been thinking about the air cleaner/fuel pump clearance and decided to experiment with the extra assembly from the 16hp parts motor. A bit of dremel work and I think I have the necessary clearance.
Pics 1 and 2 show as is.
Pics 3 and 4 show the areas I cut marked with a Sharpie
Finally the other pics show the area I opened up.  Easier to notch the base for clearance than make up a spacer.
Once I confirm there is ample clearance I will clean up the cut and seal it with some paint.
Edited by Trav1s, April 02, 2020 - 03:42 PM.
#308 Trav1s ONLINE
Trav1s
  • 3987 Thanks
  • 4854 posts
Posted April 03, 2020 - 01:54 PM
Adding the part numbers of the recent purchases for reference:
692063 - Briggs & Stratton Oil Adapter Gasket
691613 - Briggs & Stratton Exhaust Gasket (Replaces 805024, 691613, 6789766)
690931 - Briggs & Stratton Super Lo-Tone Muffler For 12.5, 16 and 18 HP Vanguard V-Twin Horizontal Engines
#309 Trav1s ONLINE
Trav1s
  • 3987 Thanks
  • 4854 posts
Posted April 04, 2020 - 11:36 AM
I have also been thinking about where to mount the external oil cooler. There is room behind the side panel to mount it in the factory Vanguard location but would rather have more air flow over it. Considering mounting it on the left side over one of the vents and behind the hydraulic control handles.. I would need to figure out lines and would rather not notch the panels. Maybe some hard lines that meet up with the hoses next to the engine would work. Hmmm
Edit - sorry the pics are sideways.
Edited by Trav1s, April 04, 2020 - 12:04 PM.
  • KennyP, Leonard VanCamp and Mark 149 J. have said thanks
#310 Trav1s ONLINE
Trav1s
  • 3987 Thanks
  • 4854 posts
Posted May 17, 2020 - 08:00 PM
Been busy with a new and finally a full time job. The income increase will help stuff at home as the past year without full time work has been rough. Finally ordered a start improvement kit for the 318 and can move forward with wiring. Found the kit on amazon with sealed terminals on the relay and it will be here tomorrow.
Edited by Trav1s, May 17, 2020 - 08:01 PM.
#311 KennyP ONLINE
  • 48998 Thanks
  • 51684 posts
Posted May 18, 2020 - 04:28 AM
Glad life is getting back to 'normal' for you! Looks like a quality product. Haven't needed one for my 316 as yet, but I use it nearly every day!
  • Mark 149 J. said thank you
#312 Trav1s ONLINE
Trav1s
  • 3987 Thanks
  • 4854 posts
Posted May 18, 2020 - 07:02 AM
My practice of doing things right the first time after learning some hard lessons pays off in the end.
