* * * - - 2 votes
2753 replies to this topic
#2716 ericandelaine1975 OFFLINE
ericandelaine1975
  • 27 Thanks
  • 19 posts
Posted May 03, 2020 - 02:31 PM
Slowly making progress on my stock altered pull tractor. Finishing all the little things now. Fired it up for the first time today.d55cec869c1e19f129b07aa57d79db24.jpg
Sent from my XT1650 using Tapatalk
  • dualresponse1731, IHCubCadet147 and jcp7hp have said thanks
#2717 hankll OFFLINE
hankll
  • 106 Thanks
  • 83 posts
Posted May 25, 2020 - 09:41 PM
Pulled my Bolens 1000 out of storage on May 3.... Have bought a TR-10D to put in it. Rebuilding clutch and replacing driveshaft bearings - waiting on the mailman for the parts.
Doing rust removal with a cup brush on all the frame... And today laid trial coat of brown to see how I like the color... Getting things done, in between rains ... I'm an actual shade tree mechanic! I'm working outside with my Bolens sitting on my flatbed utility trailer. My shade tree has my hoist up in the first fork.... Works well 4ab28c2ab8a0411b03e9754bd08bb5a2.jpgbc539f1ca22a8d4ad3d26380a4b73f00.jpg87d03a1beae8219e2e7c5f337cdd43bf.jpg
Sent from my Pixel 3 using Tapatalk
  • AGMANN, IHCubCadet147 and jcp7hp have said thanks
#2718 kip362000 OFFLINE
kip362000
  • 9 Thanks
  • 3 posts
Posted June 06, 2020 - 10:46 PM
Here is how the subrames were designed for the pre-1971 tractors. This system would probably interfere with the running boards on newer machines. I have a '69 AC  B-210 with an L-112 loader on it. Make sure the woodruff keys are not worn on where your right hand differential is attached to the axle tube. If it gets slop it can increase the likelihood of cracking the axle tube. Using a loader may put greater stress on the differential and axle tube.
I have been using it and I do see why you said that the front half and rear half of the tractor bolting together on the BGB was a weak point. Found most of the Bolts loose. I will have to figure out a way to mount the front frame directly to the rear frame incase using the loader is what made the bolts come loose. I have a quick question the hydraulic pump was the original 1974 pump with a 7/16" shaft and it broke today  how do I find out what PSI and GPM I need to replace it? I figured I would go to a 1/2" shaft since I can't find a 7/16" one.
  • jcp7hp said thank you
#2719 Alc OFFLINE
  • 9126 Thanks
  • 8335 posts
Posted June 07, 2020 - 05:25 AM
Was using the Kubota all day yesterday and as it was getting late and wanting to get a few more cinder blocks moved I saw the LF tire flat . All right at least it was the tire that was needing air every few days , thinking whatever was the problem was it just got worse . Nope a nail sticking through it ,  dismounted and patched that hole , I couldn't find any other spots without dunking the tube but I was in a hurry , remounted and started to air ip up , and uo and up crap I pinched the tube  :wallbanging:    dismount it again ,  1 spot , NO 2 spots NO 3 spots NO 4 places in a group  :wallbanging:  :wallbanging:   at least one of my large patches covered all .
  • KennyP, propane1, Leonard VanCamp and 4 others have said thanks
#2720 426tractorguy OFFLINE
426tractorguy
    andweknow.com
  • 1108 Thanks
  • 588 posts
Posted June 22, 2020 - 01:22 PM
i stripped paint off part of it and put tons of stuff to get for it in the cart on amazon and ebay
#2721 chuckieb OFFLINE
chuckieb
  • 30 Thanks
  • 17 posts
Posted August 06, 2020 - 07:24 PM
Finally had a chance to take my MF1655 for a run after sitting for over a week. Low and behold , I think I found my problem with losing prime while sittingh around. The vacuum hose from the engine block to fuel pump was quite loose. Put a hose clamp on it and now gas is right there. She took right off and I did some mowing and clearing brush at thye lower end of our place. Also charges good with the new regulator so very happy. Have a great day and stay safe. Will try to put up some shots of her asap.
#2722 1967Craftsman's OFFLINE
1967Craftsman's
  • 164 Thanks
  • 109 posts
Posted August 16, 2020 - 08:40 AM
Been taking the electric start Craftsman I just bought apart lately, fixing little things that bother me that I don't like. Got the fenders off as there was only 2 blots holding them on instead of 3 on each side, and seat off it so far as I want to repaint the seat bracket because it is red and the rest of the tractor is yellow and white. Also fixed the foot rest pedal because it was loose, I had to find a 2 inch spacer to fit that as well. Pictures to hopefully come soon.
  • propane1, IHCubCadet147 and jcp7hp have said thanks
#2723 IHCubCadet147 ONLINE
IHCubCadet147
  • 2398 Thanks
  • 951 posts
Posted August 21, 2020 - 08:42 PM
I replaced a broken tie rod end on my 129.
Before:
D2134A69-C4B9-4EE9-B7C9-5966B5E4D4CA.jpeg 887D1CDC-E065-41D4-88F0-0151C8A25DA1.jpeg
After:
FBB209E0-DC9B-4159-A360-51E0CEDE4A01.jpeg 833CE6B7-71D7-4C25-B851-7287C2FDF3DC.jpeg
All ready to cut grass tomorrow!
  • jhn9840, KennyP and jcp7hp have said thanks
#2724 1967Craftsman's OFFLINE
1967Craftsman's
  • 164 Thanks
  • 109 posts
Posted August 24, 2020 - 08:25 AM
Here are some pictures to follow up my post, more to come soon.......
Edited by 1963Craftsman's, August 24, 2020 - 08:25 AM.
  • jhn9840, KennyP, IHCubCadet147 and 1 other said thanks
#2725 KennyP ONLINE
  • 53436 Thanks
  • 53421 posts
Posted August 24, 2020 - 10:49 AM
Worked on the  '74 JD 112 w/electric lift. Was having an issue with it not going back down. Thought it might be a solenoid, but found it to be a bad connection at the solenoid. Had to take the battery and tray out to get to the mess. This also has a 30A circuit breaker for each solenoid.
In the pic above, the two solenoids are at the top. The small wire(yellow) that plugs into the front on the LH one was loose fitting and corroded some. Cleaned that up and it works fine.
  • Leonard VanCamp, IHCubCadet147 and jcp7hp have said thanks
#2726 426tractorguy OFFLINE
426tractorguy
    andweknow.com
  • 1108 Thanks
  • 588 posts
Posted October 20, 2020 - 12:16 PM
took apart the tranny on my jacobsen again. also just got a sandblaster so i can get paint off way easier
#2727 jcp7hp ONLINE
jcp7hp
    ( ಠ ͜ʖಠ)
  • 1474 Thanks
  • 695 posts
Posted November 05, 2020 - 10:09 AM
Well technically yesterday i put the foot rests back on the Penncraft... i need to tighten the bolts that hold it on though because i cant put my weight on the footrests. Next tuesday ill finish it. Either way i got the penncraft body off, sprocket key replaced, drive chain soaked and cleaned, put on right way, Then got the engine started after a year. Alot of work but shes all ready! gonna be working and pulling stuff! This winter ill be pulling some (medium) sized logs!
  • IHCubCadet147 said thank you
#2728 jcp7hp ONLINE
jcp7hp
    ( ಠ ͜ʖಠ)
  • 1474 Thanks
  • 695 posts
Posted November 05, 2020 - 10:11 AM
Now thats heavy duty!  :rocker:
  • jhn9840 said thank you
#2729 jcp7hp ONLINE
jcp7hp
    ( ಠ ͜ʖಠ)
  • 1474 Thanks
  • 695 posts
Posted November 05, 2020 - 10:26 AM
pics of project
  • jhn9840, Vrdaddy and IHCubCadet147 have said thanks
#2730 Kster526 OFFLINE
Kster526
  • 2969 Thanks
  • 1264 posts
Posted November 08, 2020 - 03:37 PM
Got the snow blade ,weights, chains mounted on the 210
still need to change oil , air filter and spark plug then
just wait for the punishment from Mother Nature
  • KennyP, Vrdaddy, IHCubCadet147 and 1 other said thanks
