Shaw Du-All -14
  • This topic is locked This topic is locked
21 replies to this topic
#16 skyrydr2 OFFLINE
  • 3,869 Thanks
  • 3,401 posts
Posted December 08, 2011 - 04:00 PM
That IS very cool , and you are correct Kenny, it must be grounded to read voltage. I have both on my diesel.
  • jdcrawler said thank you
#17 mjodrey OFFLINE
Posted December 08, 2011 - 04:43 PM
Very clever belt brackets, those are way cool. I think a volt meter shouldn't be in line with the generator, just reading voltage from the battery. I think one side should be grounded. And I do like your shin protector, that will still hurt but shouldn't take as much hide off. Looking great as usual, Ray. Thanks for sharing all your builds.
:ditto::yeah_that:
#18 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,857 Thanks
  • 1,847 posts
Posted December 08, 2011 - 05:42 PM
I did some playing around with the volt meter today just to make sure I understand how it works.
I hooked it up to the switch and grounded the other terminal and it worked just fine.
However, I've decided to leave the amp gauge on the tractor because that is most likely what would have been used on it back in the 40's or 50's.
#19 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 08, 2011 - 05:54 PM
Great setup Ray, looks like it will all work out better. Keep up the great fab work.
#20 KennyP ONLINE
  • 37,377 Thanks
  • 45,442 posts
Posted December 08, 2011 - 05:58 PM
Glad the volt meter worked for you. I agree on the amp gauge, though. That time period would make it more normal.
#21 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted December 09, 2011 - 10:37 PM
I think you were trying to have the current pass through the voltmeter like the ammeter does. But the volt meter is just a probe, cant pass current through it
#22 MH81 OFFLINE
Posted August 28, 2016 - 09:12 AM
Next phase of build can be found here
http://gardentractor...shaw-du-all-15/
