446
5 replies to this topic
#1 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted December 02, 2011 - 01:40 PM
possible to pull start a 446:confuse:. if so how would i do so? thanks in advance
#2 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted December 02, 2011 - 01:49 PM
Sorry, those Case and Ingersolls can NOT be pull started because the hydraulic system that drives them does not facilitate. You WILL need a starter to get it going.
#3 mjodrey OFFLINE
Posted December 02, 2011 - 02:24 PM
Casey is right,there is no mechanical connection between the wheels and the engine. Those Case tractors are only have a fluid connection ,( Hydraulic Drive ) .
#4 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted December 02, 2011 - 04:13 PM
Do you mean pull it with a car or use a rope or recoil starter to do the job? I don't know if you could pull start a 16hp.
#5 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted December 02, 2011 - 04:17 PM
Brian, it wouldn't matter if he could pull start it with a rope or not because an Onan, to the best of my knowledge, has not rope pull pulleys on it, and with the pump on the output there is no pulleys to wrap a rope around there either. Only way to start those is with a starter...
#6 cp7 OFFLINE
cp7
  • 59 Thanks
  • 148 posts
Posted December 02, 2011 - 07:24 PM
Never say never.
Granted there's nowhere to mount it on a Case in factory configuration but get rid of that pesky clutch and get you a recoil starter. Replacing the elecric starter would be more practical though.
Here's the Onan parts blowup for the model B43.
And then a pic of a CCK with a starter cup.
