New engine ordered for repower
69 replies to this topic
#46 Cvans ONLINE
  • 6,667 Thanks
  • 6,134 posts
Posted August 21, 2012 - 05:04 PM
I just got it clear of the housing and it is a Yanmar. The bad part is that it says on the information tag that it is for "constant speed only" :mecry: But - the governor arm on the pump looks like it is meant to have a throttle cable hooked up to it so I'm not giving up yet. I still have to take the alternator and compressor off and the mounting frame before it is out in the clear. Than I will wash it and take photos.
#47 Cvans ONLINE
  • 6,667 Thanks
  • 6,134 posts
Posted August 21, 2012 - 07:40 PM
Looks like this little Yanmar is bigger than I thought. The tag says 523cc so If I can get it to throttle this could turn out to be a very usable engine. I had thought that the main seal was leaking but I found that the oil filter was just snug and had been leaking. the oil was finding it's way to the flywheel and showed up in a lot of places after that.
That's a 1 foot rule in the photos to give an idea of the size.
Looks like the engine is putting out 7kw at 2400 rpm. That works out to about 9.37hp.
#48 olcowhand ONLINE
  • 41,252 Thanks
  • 31,446 posts
Posted August 21, 2012 - 07:53 PM
At 3600 rpm, it puts out right at 13hp. http://www.centrodie...ries_sheets.pdf
#49 olcowhand ONLINE
  • 41,252 Thanks
  • 31,446 posts
Posted August 21, 2012 - 07:59 PM
When can you ship that other one my way Chris? :smilewink:
#50 Cvans ONLINE
  • 6,667 Thanks
  • 6,134 posts
Posted August 21, 2012 - 08:12 PM
From the looks of the spec. sheet I would have to wind these up to 3600 rpm to get 13hp out of them. That's way to small for anything you have Daniel. Your bucket is pretty full and I don't want to be adding to your burden by making you use an under powered tractor :p On top of that I don't even know if I can throttle the darn things yet. Hopefully I can make some headway on that tomorrow if it doesn't get too hot. I have to call and see if the other one is available yet.
Looks like I'm pretty good at repeating what you have said. Is that an echo I hear? :rofl2:
#51 olcowhand ONLINE
  • 41,252 Thanks
  • 31,446 posts
Posted August 21, 2012 - 08:21 PM
With my Massey 1855, I rarely ask for more than half to 3/4 of what the 18hp Onan can develop. A smaller diesel will more than name up for hp with torque. The Yanmar I hope to put into my 1855 loader tractor this winter is a 16hp 3TNE66. Yes, I have more on my plate than I can handle as it is.....so just keep that extra Yanmar Chris. :smilewink:
#52 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted August 31, 2012 - 12:07 PM
My Kubota Z482 was set up for constant speed only. However, there was a bolt with a locknut that acted like a throttle stop. I just backed the bolt off a little and "voila" variable speed.
Also, you can find the displacement and serial number for the engine right below the fuel return line on the right side of the engine as viewed from the flyhwheel end.
Another curious thing about Kubotas--- the first letter designates the number of cylinders...in German. Here's the breakdown:
Z - Zwei (2)
D - Drei (3)
V - Vier (4)
So, a Z482 engine is a two cylinder with 482 cc's displacement.
HTH,
Steve
  • KennyP and Toolpartzman have said thanks
#53 KennyP ONLINE
  • 38,474 Thanks
  • 45,969 posts
Posted August 31, 2012 - 12:11 PM
Good info, Smitty!
#54 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Chris
I know you can tweak the hp of a diesel engine with different sized injectors and with different settings on the fuel pump. I would guess you could get 2 to 3 more hp with those engines.
It looks like those little Yanmars are a pretty good fit for GT use... The extra torque of the diesel engine certainly helps. And, torque on a diesel isn't just a function of the length of the stroke. Since the fuel tends to burn for a longer time than gasoline, you have a longer "push" through the stroke of the piston...
Regards,
  • Cvans said thank you
#55 Cvans ONLINE
  • 6,667 Thanks
  • 6,134 posts
Posted August 31, 2012 - 06:25 PM
I did get the control panel made and then the weather got very hot. Now it's cooled down and I and the wife have a bit of a bug so not much has been getting done. I'm also replacing the fuel tank in my plane so I need to get that done so I can attend a fly inn in the near future.
My engine also has the throttle stop bolt and I plan on backing that off and see if I can throttle it. Hopefully next week I can make some more progress on it.
#56 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted September 01, 2012 - 08:05 AM
As I have stated before, there is no replacement for cubic inch displacement! This is the key factor when choosing a replacement . Diesel or otherwise . Only real advantage is the diesels are usually very good on fuel com paired to its equal on gasoline.
Now you need to look at the torque figures of both engines and com pair rpms and values if they are pretty close then HP doesn't really matter. But if they are way off then issues will surely rear their ugly heads. Overheating for one.
The wayi see it is bigger is almost always better, especially talking diesel . They last longer and get very good fuel usage doing only half the load .
You run a little diesel hard all day and it isn't going to last as long as a larger one working half as hard and that's fact.
#57 Trav1s ONLINE
Trav1s
  • 3,311 Thanks
  • 4,367 posts
Posted September 02, 2012 - 07:39 AM
That looks like a great engine to drop in a JD 300/314/316k/317. Looking forward to the continued work on your project.
#58 Chuck1947 OFFLINE
Chuck1947
  • 2 posts
Posted September 06, 2012 - 12:01 AM
Hello Smitty,
New guy here. Was glad to see your post about the Kubota z482. I am wanting to order one from ebay but the seller stated that it was a constant speed. My question is, are all the z482's alike or could I assume that the one on ebay would be able to be converted to a variable speed engine? Thanks If you go to ebay you can just search "Kubota z482" and check it out.
Thanks
Chuck in SC
#59 mjodrey OFFLINE
  • 2,356 Thanks
Posted September 06, 2012 - 06:21 AM
Chuck1947,just wanted to say welcome to the forum.Glad to have you with us.
#60 Cvans ONLINE
  • 6,667 Thanks
  • 6,134 posts
Posted September 06, 2012 - 10:33 AM
Welcome Chuck. Nice to have you here.
So far the constant speed engines that I have run were able to run at variable speeds. A couple had to have the throttle arms modified but that was simple. I'm about to try another and will report the results. Too many things keep popping up and getting in the way :smile1:
