New engine ordered for repower
69 replies to this topic
#16 Cvans ONLINE
  • 6,468 Thanks
  • 6,061 posts
Posted December 01, 2011 - 05:47 PM
Ring a ding ding ding :bigrofl:
I said 2 cylinder not 2 cycle :smile1:
I guess the 2 cylinder thing goes back many years to my A & B Poppin Johnnies.
#17 olcowhand ONLINE
  • 40,389 Thanks
  • 31,181 posts
Posted December 01, 2011 - 06:16 PM
Hey, just had an idea! Put some Bel Ray 2 stroke racing oil in the diesel fuel! It'll give top end lubing, plus put out that lovely smell Bel Ray gives off!
#18 Guest_ACguy1994_*
Guest_ACguy1994_*
  • Guests
Posted December 01, 2011 - 06:43 PM
how many horse is the engine you ordered? also i can attest to the 3 cylinder engines running smooth. im selling a kubota b1550 for a family friend, and she told me to drive the kubota around (which i loved) and the lil 17 horse 3 cyl in it is smooth.
#19 Cvans OFFLINE
  • 6,468 Thanks
  • 6,061 posts
Posted December 01, 2011 - 07:25 PM
Back in the day I remember the distinct smell of Castor Oil. Haven't smelled that in years. Never ran it myself but you sure knew who was.
I think the Z600 is rated at 14.5 to 15hp. range. I know it is a little less than the Z620 at 16hp. I've never even come close to stalling it so the Z600 should be fine. I also have available a Z700 out of a Kubota CUT but it is a large block 2 cylinder. I'm going to look at it and a ZB400 as he has offered them at a very reasonable price.
Boy it's hard to say no when someone does that. I think I will take the SportTrac so I won't be tempted to bring anything else home.
#20 JDBrian ONLINE
  • 9,613 Thanks
  • 14,144 posts
Posted December 01, 2011 - 07:52 PM
Ahhh...I just love the smell of 2 stroke smoke in the morning!
#21 olcowhand OFFLINE
  • 40,389 Thanks
  • 31,181 posts
Posted December 01, 2011 - 07:56 PM
Back when I raced, I used Bel Ray MC1+ exclusively & NEVER had an engine failure! Never liked the smell of bean oil myself, but the Bel Ray smelled oh so good!
#22 olcowhand ONLINE
  • 40,389 Thanks
  • 31,181 posts
Posted December 01, 2011 - 08:05 PM
Chris, check these diesel powered heaters out. Ad says gasoline powered, but look at the injector line, and the tag says diesel too. Not a big engine, but cheap if you were close enough for pickup.
Military Surplus Heater, Engine, & Shelter, Gas, Ground Type H, Used | eBay
  • Cvans said thank you
#23 Cvans ONLINE
  • 6,468 Thanks
  • 6,061 posts
Posted December 01, 2011 - 09:11 PM
Those look like they would be fun to mess with. I'm gong to see if I can get enough info from the tag photo to track them down for more information. Would like to know who's engine is in them.
#24 olcowhand ONLINE
  • 40,389 Thanks
  • 31,181 posts
Posted December 01, 2011 - 09:17 PM
He has another listing for same type heater that DOES specify diesel powered, and he has 2 of them. I forgot to copy the link...sorry, as he has 16 pages!
#25 Cvans ONLINE
  • 6,468 Thanks
  • 6,061 posts
Posted December 01, 2011 - 10:20 PM
Your trying to get my place to look like his aren't you. Ain't going to happen! Fun to dream though.
#26 skyrydr2 ONLINE
  • 3,870 Thanks
  • 3,403 posts
Posted December 02, 2011 - 05:08 AM
Powersteering will be a must on the Ford, as the steeringbox is not a very good ratio. The tractor with that Eaton transmission is capable of many many hard tasks, mine works its butt off! I sort of wish it had just a bit more HP, as that transmission will shut the engine off !
And if you put a loader on it, you may find it needing more.
These rigs mow really nice too, are you planning to mow with it ? If so the pto clutch will need to be mounted. The driveshaft should basically bolt right on to the crank pulley, mine did, but it was tight.
I made a cradle basically, that contains all the engine components except the radiator , that is mounted to the frame . I can undo a few wires ,2 hydraulic hoses and 6 bolts and slip the engine out complete with radiator and battery.
My biggest issue was a fuel tank, not much room left under the tin for one, so I made one out of the left fender, holds 3 gallons exactly .
#27 Cvans OFFLINE
  • 6,468 Thanks
  • 6,061 posts
Posted December 02, 2011 - 10:08 AM
skyrydr2 I have an idea that I might be requesting photos down the line. Your component system sounds very desirable to me. I'm a very big fan of "simple":laughingteeth:
I also can't see the sense of re-engineering something that is already successful. With your permission of course.
I will probably try and get the PTO hooked up. It worked out well on the Bolens so I would like to do it again.
Looking forward to getting started.
#28 skyrydr2 ONLINE
  • 3,870 Thanks
  • 3,403 posts
Posted December 02, 2011 - 02:25 PM
Copying someone's work is the largest form of flattery :thumbs:
I think I have drawings of the mounts I made. But mine is the D 600 so there may be a few discrepancys. ? A teaser....
  • Utah Smitty said thank you
#29 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted August 19, 2012 - 12:11 AM
Where can we find the thread on the diesel repower of the Ford LGTs? I remember reading it when I first started with the forum last year, but I can't seem to find it, now.
Utah Smitty
#30 Salatino OFFLINE
Salatino
  • 29 Thanks
  • 188 posts
Posted August 19, 2012 - 09:45 AM
"On the pipe"-
Daniel I haven't heard that expression since my good old days of dirt biking back in the 1970s !
I was just thinking the same exact thing, you took the words outta my mouth as I was reasing, " On the pipe " I use to ride dirtbikes & 4-wheelers also. Me and about5 friends,we all had banshees! Man them things were so cool & fast,even stock! Use to love goin out ridin with all my buddies
