Used Lathe & Mill Yesterday
7 replies to this topic
#1 olcowhand ONLINE
  • 40,355 Thanks
  • 31,172 posts
Posted November 27, 2011 - 02:11 PM
Yesterday I pretty much took my day off to do nothing. But after lunch, I had to have a few minutes shop time. So the stub shaft on the Yanmar engine needed machining. The engine came out of a John Deere Gator & the stub was tapered for the belt clutch. When this engine goes into my Massey w/loader, I need the stub to hold a pulley to drive my hydraulic pump. So I chucked the stub in my lathe & turned down to 1". Then I put it in my end mill & using a keyway cutter, machined in the key slot. Going to be a while likely before fitting the diesel in the tractor, but at least this part is ready.
I made the drive shaft adapter for this same project (below) a few weeks ago with the same 2 tools. I could not do hardly any of my projects without these machining tools!
#2 JDBrian OFFLINE
  • 9,608 Thanks
  • 14,144 posts
Posted November 27, 2011 - 04:00 PM
Those look great Daniel. What's the adapter made of? Thats quite a complex bit of machining on the adapter.
#3 KennyP ONLINE
  • 37,457 Thanks
  • 45,483 posts
Posted November 27, 2011 - 04:05 PM
Nice job, Daniel. Parts look great. Must be nice to have those tools handy.
#4 massey driver ONLINE
massey driver
  • 1,400 Thanks
  • 1,569 posts
Posted November 27, 2011 - 06:44 PM
Thats some very nice work Dan. Maybe some day I'll get some tools like that then I'll have to take some course on how to use them or I should say refresher course been 35+ yrs since using a milling machine.LOL Larry.
#5 olcowhand ONLINE
  • 40,355 Thanks
  • 31,172 posts
Posted November 27, 2011 - 07:08 PM
It looks like aluminum, but it's actually a higher grade steel. Started as a piece that came in a set of cylinder sleeve pullers from an auction. Not machined for sleeve pulling, so I suppose it was just a blank to be custom machined for a certain sleeve.
#6 AcreFarm OFFLINE
AcreFarm
  • 110 Thanks
  • 359 posts
Posted November 27, 2011 - 08:34 PM
Very good work. Now I know who to send my parts to that need machining! :D
#7 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted November 27, 2011 - 08:50 PM
The parts look great. I would love to get a lathe and a mill at some point.
#8 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted November 27, 2011 - 09:40 PM
Daniel, Your work looks GREAT, you always do a fantastic job on your GT's.:worshippy1:
