Refurbishing the #49 Blower
22 replies to this topic
#1 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,697 posts
Posted November 24, 2011 - 06:02 PM
Finally getting started on the JD 49 snowblower! Mostly just needs cleaned up & repainted;
Got the black parts off & painted today;
grnspot
#2 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted November 24, 2011 - 07:10 PM
is this the one your going to lend me lol . dont think it would work good on gravel
#3 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,697 posts
Posted November 24, 2011 - 07:37 PM
It'll be used on gravel (3/8" chips)! I've used a 37A for several years with god results. Does throw some grave too though, just have to keep the runners down! Helps if the drive is frozen.
This one will go on the 314, have a 54, 4-way blade for the 420~~ grnspot
#4 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted November 24, 2011 - 07:41 PM
maybe i need to find one for my 400
#5 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,697 posts
Posted November 26, 2011 - 05:23 PM
Had to adjust the drive pulley, it had more than a 1/4" of wobble! Tried a rubber dead-blow mallet first, with no results, so then I broke out the 3# hammer & wood block, no more wobble! Pulley was also missing the key, replaced it & the missing set screw in the auger sprocket.
Got most of the paint & rust cleaned off the shell today, still a ways to go;
grnspot
#6 KennyP ONLINE
  • 41,000 Thanks
  • 47,160 posts
Posted November 26, 2011 - 06:13 PM
Looking good. I love to 'tweak' things with the hammer. Keep on posting, I might learn a bit about blowers.
#7 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted November 26, 2011 - 08:27 PM
when i tweak things with a hammer its not a good thing . lol
#8 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,697 posts
Posted November 28, 2011 - 07:47 AM
Finished cleaning & primed yesterday. Rustoleum "Rusty Metal Primer" on the bottom& inside the shell;
Rustoleum "Gray Automotive Primer" on the outside of shell & other parts:
EZ-Slide, graphite paint in the chute.
Hope to shoot some JD yellow tomorrow! ~~ grnspot
#9 KennyP ONLINE
  • 41,000 Thanks
  • 47,160 posts
Posted November 28, 2011 - 09:51 AM
Looks good! Ought to look & perform real nice when you are done!
#10 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted November 28, 2011 - 04:40 PM
Looks good Grnspot. I recently painted my 54 blade. I primed a large bare spot with Tremclad (Rustoleum) grey primer then sprayed it with Yellow. The yellow wore off where the primer was after the first plow session. It seems like it didn't adhere to the primer. On the rest of the blade, which I only sanded before painting, the paint stayed on OK! Just one of those things I guess. I hope yours holds up better!
#11 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,697 posts
Posted November 29, 2011 - 06:01 PM
Well, it's YELLER' again!
I've got too much going on the next couple of days,hope to put it back together Friday! ~~ grnspot
#12 KennyP ONLINE
  • 41,000 Thanks
  • 47,160 posts
Posted November 29, 2011 - 06:17 PM
Looks good to me! What do you plan for the inside of the chute? It doesn't look painted in there yet. When you put it back together, can you name the parts so I can get more of an idea of what is what? I haven't even seen a blower in real life.
#13 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,697 posts
Posted November 29, 2011 - 07:32 PM
The chute is coated with EZ-Slide, a graphite-based paint!
It worked well for me on the 37A I had before this one! ~~ grnspot
#14 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted November 29, 2011 - 08:36 PM
I painted the inside of mine with POR-15 paint, supposed to be tougher then nails.
Then I top cated it some of their White top coat.
#15 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,697 posts
Posted December 02, 2011 - 07:55 PM
Finished the blower up today, at least until I get the tractor ready:
Put the chute together & installed, drift cutters on; HPIM2234 (640x478).jpg
Installed the decals & moved it out of the shop around 5 pm; HPIM2237 (640x478).jpg
The chute control rod will go on later, when I get the 314 ready. Need to change fluids, & install the cab on it yet! ~~ grnspot
