1966 MF10 Restoration
200 replies to this topic
#106 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2028 Thanks
  • 3172 posts
Posted January 29, 2012 - 01:49 PM
Well I have cleaned, adjusted, painted and reinstalled the Steering Column, so I thought would compare the the MF10 column to a Cub Cadet column since they are both made by the Ross Company.
First the MF10 column is shorter.
And the mounting holes are different.
The side plate is different.
But the internals are all the same.
http://www.youtube.com/watch?v=AlQ7Ij90pV8
Edited by Amigatec, January 29, 2012 - 02:24 PM.
  • mikebramel, HowardsMF155 and Toolpartzman have said thanks
#107 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 471 Thanks
  • 1280 posts
Posted January 30, 2012 - 07:34 AM
Hope I'm not too late with this as I've been traveling, but if you're still fighting the hood paint, try dropping it in your e-tank, it will loosen that paint and save some elbow grease----As usual THANKS for the great videos--Lee
#108 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted January 30, 2012 - 07:36 AM
I need to build a bigger tank, mine is a 5 gallon bucket. I have 4 55 gallon plastic drums I can useable a 10 amp 24 volt charger.
#109 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 471 Thanks
  • 1280 posts
Posted January 30, 2012 - 08:34 AM
I found a plastic drum and it seems to work great-particularly with smaller pieces too. I installed a drain valve in the lower side before filling, as moving a full can around can get heavy!! I use a 36 VDC golf charger and it makes a difference in time, but I keep power low on small pieces , because they will heat up.--Lee
#110 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted February 19, 2012 - 10:52 AM
I found an easy way to remove the decal from the front of the hood. I have a propane torch, I heated up the decal so that it was blistered and cracked and then the wire wheel took it right off.
I will have a video later.
#111 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted February 19, 2012 - 07:39 PM
Another update
  • KennyP and Toolpartzman have said thanks
#112 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted February 21, 2012 - 06:54 PM
I took the grill down to the body shop tonight so that the top edge can be fixed.
Edited by Amigatec, February 21, 2012 - 06:55 PM.
#113 KennyP ONLINE
  • 50026 Thanks
  • 52252 posts
Posted February 22, 2012 - 08:38 AM
Looking good! Makes me want to start on the GTV, but other things to get done first.
#114 mjodrey OFFLINE
  • 2373 Thanks
  • 13481 posts
Posted February 22, 2012 - 11:07 AM
You are making good progress.
#115 daytime dave OFFLINE
  • 5441 Thanks
  • 6770 posts
Posted February 23, 2012 - 08:45 PM
I like the progress. Almost makes me want to start a project I have here, ...... almost. :laughingteeth:
#116 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted March 31, 2012 - 07:29 PM
Another update.
#117 IHCubGuy OFFLINE
IHCubGuy
  • 1630 Thanks
  • 1641 posts
Posted March 31, 2012 - 08:49 PM
The seat that you mention, is it a seat on rails to adjust it forward and back? If so I think it's the same on that I just bought and put on my 12H. My only complaint about it is that its not as wide as I would have hoped it to be.
#118 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted May 04, 2012 - 03:49 PM
Now that the DB is finished, I will finish the MF10.
#119 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted May 05, 2012 - 04:57 PM
#120 JDBrian OFFLINE
  • 9666 Thanks
  • 14162 posts
Posted May 05, 2012 - 05:31 PM
Just noticed your post on removing the decals with a torch. If you have a heat gun that is a bit easier to control than a torch and will get the job done. I have to remove them on my MF8 as I'm getting ready to prep the hood and fender deck for paint.
