1966 MF10 Restoration
200 replies to this topic
#76 KennyP ONLINE
  • 50110 Thanks
  • 52289 posts
Posted January 09, 2012 - 09:01 AM
xrman2, down below is a site how-to section. In it is how to upload pics. Check that out.
#77 xrman2 OFFLINE
xrman2
  • 3 Thanks
  • 20 posts
Posted January 09, 2012 - 09:14 AM
I put some pictures up in with Massey/Snapper Pictures Fellow. I don't have the Ford any more! I'll have to get some pictures of Dad's herd in the spring. I do know a 16HP v-twin Vanguard Briggs works well in the MF10 also.
#78 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2028 Thanks
  • 3172 posts
Posted January 09, 2012 - 06:42 PM
I recall there being more. Maybe 5, I think.
Agco shows 6pc.
I will try it without the 3 extras. If I need extras I will have to find some.
#79 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted January 09, 2012 - 06:44 PM
I also noticed that this tractor has Sears tires on the rear, are these factory?
Another thing I have noticed is that there are 2 different brake brackets and 2 different lift arm assemblies.
#80 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted January 09, 2012 - 06:45 PM
Just make sure the belt rides down in about a quarter inch into the pulley. If it is flush with the outside of the pulley, it will wear the belt funny & these are too expensive to wear out fast.
#81 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted January 09, 2012 - 07:14 PM
The pully does have a worn spot down in the groove, I will know more when I get it back together.
#82 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted January 09, 2012 - 08:25 PM
I bought a used a used brake band and it came with a different bracket, and after looking at the parts book, it seems that the mounting brackets changed at about SN 6016. I'll do another video with the 2 bracket, and the lift handle also changed at the same time. The older handle was held on with a pointed set screw like is used on the the clutch pedal, the newer one has a square key and a set screw. And the other major difference I can see is the belt guard on the motor is different.
I'll keep looking for other changes.
#83 ckjakline OFFLINE
ckjakline
  • 1181 Thanks
  • 1173 posts
Posted January 10, 2012 - 09:55 PM
No they didn't come with sears tires.It looks like your wheels were changed also.
#84 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted January 11, 2012 - 05:50 AM
When I removed the wheels, they were loose, so maybe somebody took these off of something so they roll it around.
#85 ckjakline OFFLINE
ckjakline
  • 1181 Thanks
  • 1173 posts
Posted January 11, 2012 - 08:24 PM
Thats more than likely what happened.I'v done that already.It's not fun pushing a GT with flat tires.
#86 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 472 Thanks
  • 1280 posts
Posted January 12, 2012 - 06:59 AM
I noticed in the later M10-12 parts manual reference to " Drive Idler conversion Kit, Brake Conversion Kit". I don't know exactly what that means, but an obvious indication of some changes.
#87 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted January 14, 2012 - 07:54 PM
http://www.youtube.com/watch?v=0MHjoPBSFaA
OBP Episode 54 - Massey Ferguson MF10 Part 9 - YouTube
  • Toolpartzman said thank you
#88 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted January 14, 2012 - 08:43 PM
Looking good! you are coming along great with it. One thing I might remind you of and if you read the manual before you put it back together instead of after like I did the center vari pulley has 2 different size hubs on it and the smaller hub goes to the outside. That was something I had to change today. Keep up the good work.
#89 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted January 15, 2012 - 06:56 AM
I have spent a good amount of time with the manual and the parts book. This one had its share of PO Mods. The PO drug it behind a pickup when they took it to the mower shop. I just hope the tranny is still good.
Edited by Amigatec, January 15, 2012 - 01:45 PM.
Damn automatic spell checker
#90 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted January 15, 2012 - 01:45 PM
Well I have all the clutch/brake/variable speed drive parts back in. I told the wife I was going to hook the spring Back up and was afraid I might knock it off the stands. I told her if she heard a Loud bang followed by lots of adult language to call 911.
Luckily she didn't have to.
Edited by Amigatec, January 15, 2012 - 01:53 PM.
