1966 MF10 Restoration
200 replies to this topic
#46 IHCubGuy OFFLINE
IHCubGuy
  • 1630 Thanks
  • 1641 posts
Posted December 28, 2011 - 11:03 PM
I'm following both of you guys on your progress- I'm a ways behind though. Hydro is out and hope to prime the frame today. It must be a good feeling when re-assembly starts--Kind of like starting the return journey home, I guess.:worshippy1:
I am hoping to start this weekend on it but I am not sure it will. So far all I painted is the flint grey parts so I could at least get a rolling chassis going. I have all the tin to clean up yet and some body work that needs done to the hood and fenders. I also have the wheels to clean and paint. May clean up the wheels tomorrow evening and throw a shot of paint on them. Will see how that goes.
#47 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2028 Thanks
  • 3172 posts
Posted December 31, 2011 - 05:15 PM
Another Update
http://www.youtube.com/watch?v=TE_CUjfpvSQ
OBP Episode 49 - Massey Ferguson MF10 Part 6 - YouTube
  • MH81 and Toolpartzman have said thanks
#48 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted December 31, 2011 - 06:00 PM
Coming along good, that's a 1966 frame for sure,
no center rib under engine,
2 sets of engine mounting holes,
rear plate missing 2 holes for tiller spring bracket.
All unique features of the early MF10 Massey.
#49 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 472 Thanks
  • 1280 posts
Posted January 01, 2012 - 08:11 AM
AS usual--Great, helpful video--Thankx Amigatec. My 12 is close behind and the comparison of the frames is interesting-think mine is a '70. Some difference also in the lift slot as well. I'm still without engine though, but looking
#50 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted January 03, 2012 - 08:23 PM
What other features are unique to the early 66 model?
#51 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted January 03, 2012 - 08:48 PM
Aluminum Dash and Nosepiece are two more.
#52 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted January 03, 2012 - 08:51 PM
How are these different from the later models?
This is my first Massey, and I like to make my videos as informative as possible. I know thebCubs and DB's better.
#53 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted January 03, 2012 - 08:57 PM
From what I remember
1 - Amp meters had sharp pointy 0s
2 - Steering arm is Cast Iron, later ones were Aluminum.
3 - Rear plate is missing the 3 holes for Tiller Spring assist bracket.
4 - They had 2 sets of engine mounting holes, I think they were considering different engine manufacturers.
5 - Missing the center frame rib under the engine.
6 - I also notice that the foot PTO is not adjustable, missing the 2 nuts+bolts the later models have.
7 - Vari-Drive decal is not used, I believe in 67 when the MF12Hydra came out the MF10 got the Vari-Drive decal.
And of course 66s had the Aluminum dash and early ones had Aluminum Nose Ring.
  • IamSherwood and Toolpartzman have said thanks
#54 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 03, 2012 - 09:45 PM
Wasn't there some discussion about stick on serial# tags as opposed to riveted tags?
Does that apply here? there was a change over at some point in time.
#55 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted January 03, 2012 - 09:48 PM
My 66 and 67 both have stick on tags, when they went to rivet tags, ???
What I would really like to know is what the 2nd set of engine mounting holes fit?
The MF Executive tractors had Kohlers in them, I wonder if they were considering Kohler engines for the MF10.
#56 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted January 03, 2012 - 10:46 PM
I always was under the assumption that the second set was for the 12 Hp engine. Just an assumption, no facts. Is the 10 and 12 the same footprint?
#57 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted January 04, 2012 - 05:49 AM
[ATTACH=CONFIG]27595[/ATTACH]
[ATTACH=CONFIG]27596[/ATTACH]
[ATTACH=CONFIG]27597[/ATTACH][ATTACH=CONFIG]27605[/ATTACH]
[ATTACH=CONFIG]27598[/ATTACH]
[ATTACH=CONFIG]27599[/ATTACH][ATTACH=CONFIG]27600[/ATTACH]
[ATTACH=CONFIG]27601[/ATTACH][ATTACH=CONFIG]27602[/ATTACH]
[ATTACH=CONFIG]27604[/ATTACH]
If the early Ones used Aluminum what did the others use?
#58 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted January 04, 2012 - 05:51 AM
The 12 hp was bolted to the same holes as the 10 hp was. Also is the big hole for the oil drain?
#59 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 04, 2012 - 06:05 AM
My 10, and 12h are both 1968. They both have stick on tags.
That makes sense, what you say, about possibly using Kohler engines. Anyone have a tape measure and a 10hp kohler.
#60 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 472 Thanks
  • 1280 posts
Posted January 04, 2012 - 07:15 AM
Will, I have a 10HP Kohler on blocks in the shop (maybe not the one you're referring too tho) and my frame is ready to prime--What do you want measured?--Lee
