1966 MF10 Restoration
200 replies to this topic
#196 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2028 Thanks
  • 3172 posts
Posted August 21, 2012 - 12:25 PM
#197 KennyP ONLINE
  • 50962 Thanks
  • 52632 posts
Posted August 21, 2012 - 12:51 PM
Way to go Pat. I hope the blowby will settle down when the engine breaks in.
#198 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted August 21, 2012 - 03:44 PM
If the blowby doesn't slow down soon, I am going to remove the piston and check the oil ring. I am betting it is in upside down.
Also after checking the charging system I believe the S/G is bad. I tried drounding the F term and no change on the charge.
#199 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted August 21, 2012 - 06:08 PM
I'm going to pull the crankcase breather and have a look at it. I pulled earlier today, and I didn't see a drain hole, and I'm not sure the valve is working correctly. A new one is $39 from parts tree.
#200 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted August 23, 2012 - 05:04 AM
I'm going to move on th another project, and finish this up later.
#201 jdhon OFFLINE
jdhon
  • 1 posts
Posted August 27, 2012 - 09:15 PM
Hi
How much oil did you put in engine? Is it possibly overfull? Also is it possible the oil splasher is the wrong one or possibly put on wrong? That is a lot of oil to be going thru the motor. I doubt if an upside down oil ring could let that much oil thru? Someone must have run into this before.
Gerry from Mn.
