1966 MF10 Restoration
200 replies to this topic
#166 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2028 Thanks
  • 3172 posts
Posted July 08, 2012 - 03:38 PM
Sorry to hear you have some problems with the 10, but at least you have a game plan in place.
So, if I understand correctly, you're going to bore the old style 10 block out for a 30 over 12 piston?
Also, your old 10, do you have the mag?
Yes I have the mag coil and one of these point eleminator boxes.
Yes I have 2 HH120 motors. I found a new set of rings for $35.
#167 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted July 09, 2012 - 06:29 AM
Well it looks like I will put the TriTrac on hold for a while until I get the Massey running, I also have to fix the S/G on my Cub 129, it has quit charging.
I have a call into the machine shop to see about fixing my motor. It may be cheaper to just hone the block and buy a new piston, I did find one for about $50. I'll know more today. It's still going to cost a couple of hundred to rebuild it, I have to find the last piece of tin for the top of the motor but at least now I know what I need.
#168 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted July 12, 2012 - 11:34 AM
Since the motor in the parts Tractor isnt going to work, I have found a 10hp from a 1966 MF10 to rebuild and put in it.
#169 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted July 13, 2012 - 01:51 AM
That's good news! Glad to hear the transplant is back on track.:thumbs:
#170 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted July 13, 2012 - 03:04 AM
Well the 10 hp turned out to be a 1969 model motor, so I will be rebuilding the 12 hp that came out of it.
#171 cookiemonster OFFLINE
cookiemonster
  • 410 Thanks
  • 1274 posts
Posted July 13, 2012 - 08:23 AM
More power!
Way to roll with it. Can't wait to see the next round of pics.
#172 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted July 14, 2012 - 05:04 PM
Getting the motor ready.
#173 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted July 15, 2012 - 07:55 AM
Well I don't normally worry about how much a project is going to cost, but I figure I have spent maybe $1000, most of that on the motor, tires, and paint, on the MF10 so far, and I have maybe $500 to go until its finished. I have a used steering wheel that will need to be repaired, and I need a center cap for it, and I need a seat.
The only part I need for the motor now is the pistonand rings, then all the little things like fuel line, fuel filter, oil, air filter, muffler, and belts. The motor has been the most expensive so far. I bought a head, carb, flywheel, top tin for the head, and gaskets.
I'm on the home run stretch now.
Edited by Amigatec, July 15, 2012 - 07:55 AM.
#174 KennyP ONLINE
  • 50110 Thanks
  • 52289 posts
Posted July 15, 2012 - 08:23 AM
Sounds like you are on a roll, Pat! Good luck with this project!
#175 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted July 16, 2012 - 11:16 AM
Looking at the grill and hood on my 2 Massey's I have noticed the hinge is different and there seems to be something missing at the bottom. Does anyone have a good picture or a parts book for a 1974 MF12?
#176 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted August 10, 2012 - 06:47 PM
Well after being on back order forever I finally got the piston today, I still have the head bolts on order, but I may enough to put it back together.
Edited by Amigatec, August 10, 2012 - 06:47 PM.
#177 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted August 11, 2012 - 06:16 PM
I took th motor down to the mower shop today, and have him do the valves and install the piston.
#178 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted August 11, 2012 - 06:24 PM
This is the Grill that was on my 66 MF10.
#179 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted August 11, 2012 - 06:35 PM
I figured it out, it's off a MF16.
#180 Amigatec OFFLINE
Amigatec
  • 2028 Thanks
  • 3172 posts
Posted August 14, 2012 - 07:37 PM
The motor is ready, I will be getting Saturday and start reinstalling it.
