310 clutch adjustment
7 replies to this topic
#1 Guest_ACguy1994_*
Guest_ACguy1994_*
  • Guests
Posted November 23, 2011 - 05:15 PM
when i press int eh clutch on the 310 i dont think it is engaging all the way because when i shift it grinds a little in the higher ranges. is there an adjustment?
#2 MH81 OFFLINE
  • 28,446 Thanks
  • 29,126 posts
Posted November 23, 2011 - 08:27 PM
OK, Here is the Owner's Operator's manual: 310 / 312 Owner's Operator's - Manuals - Garden Tractor Talk - Forums
Clutch Adjustment is on page 14.
And the Parts List: http://gardentractor...312-parts-2069/
Edited by MH81, November 23, 2011 - 08:32 PM.
#3 Guest_ACguy1994_*
Guest_ACguy1994_*
  • Guests
Posted November 24, 2011 - 06:43 PM
alright, i adjusted these 2 nuts, but not too much of a difference. it only grind sometimes now.
#4 MH81 OFFLINE
  • 28,446 Thanks
  • 29,126 posts
Posted November 24, 2011 - 07:02 PM
Are the brakes adjusted right? If they aren't, sometimes that will cause grinding, as the tranny turns more readily.
#5 Guest_ACguy1994_*
Guest_ACguy1994_*
  • Guests
Posted November 24, 2011 - 09:13 PM
no idea on the brakes but there was play in the clutch pedal until i adjusted it.
#6 sammiefish OFFLINE
sammiefish
  • 8 Thanks
  • 26 posts
Posted December 03, 2011 - 08:48 AM
Like MH said, the brake band needs to "brake" after the pulley tension is released or the
transmission will continue to spin... you could also just wait for the transmission to stop
spinning before changing gears but that is time consuming when trying to get a job done.
#7 Guest_ACguy1994_*
Guest_ACguy1994_*
  • Guests
Posted December 03, 2011 - 01:39 PM
its working alright now, but its not running again. i think it keeps killing spark plugs.
#8 skunkhome OFFLINE
skunkhome
  • 322 Thanks
  • 455 posts
Posted January 03, 2012 - 01:36 AM
I recommend that you adjust according to the manual starting with the proper brake adjustment and continuing through till you get to the free play on the clutch rod. If the brakes are too tight it will prevent the clutch from traveling far enough to fully disengage.
