Any info on these 2
20 replies to this topic
#1 IamSherwood OFFLINE
  • 8,390 Thanks
Posted November 22, 2011 - 07:05 PM
I realize that they're not GT stuff, but was hoping someone could shed some
light on what I have here.
I might think about selling them, as they are to big for my MFs.
What might they be worth.
The plow is Mod# 10-8 Ser# 29265.
Nothing on the discs.
Any help appreciated
Thanks
#2 MH81 OFFLINE
Posted November 22, 2011 - 07:12 PM
Thanks
Pics?
#3 IamSherwood OFFLINE
  • 8,390 Thanks
Posted November 22, 2011 - 07:29 PM
Pics?
Oh yeah, DUH.
#4 caseguy OFFLINE
  • 1,627 Thanks
Posted November 22, 2011 - 07:37 PM
I don't know much about the plow, but judging by the wooden hitch beam on the discs, I'd say they're fairly old. May even be som hand forging in the framework at the back. They also look like someone may have made some modifications or repairs at some point.
#5 IamSherwood OFFLINE
  • 8,390 Thanks
Posted November 22, 2011 - 07:41 PM
The discs have a frame bolted on top to carry extra weight. That's coming off as soon as it gets near the torch.
#6 Guest_ACguy1994_*
Guest_ACguy1994_*
  • Guests
Posted November 22, 2011 - 07:45 PM
i could see a larger gt pulling disks, like a bolens ht, a simplicity power max, a wheel horse d series, cub cadet super GT ect. the plows, maybe a diesel gt in a low gear.
#7 IamSherwood OFFLINE
  • 8,390 Thanks
Posted November 22, 2011 - 07:58 PM
Ok, I forgot. A tractor for each implement, is the rule.
So, I should keep them, and get the right machine for them?
#8 Gibby OFFLINE
Gibby
  • 96 Thanks
  • 360 posts
Posted November 22, 2011 - 08:14 PM
I think you already know the answer.
#9 olcowhand OFFLINE
  • 40,385 Thanks
  • 31,181 posts
Posted November 22, 2011 - 08:19 PM
I'm going to guess on the plow as being early 50's, possibly late 40's. What is the cutting width of each plow? I have seen 2-bottom Dearborn plows that were 12".
#10 IamSherwood ONLINE
  • 8,390 Thanks
Posted November 22, 2011 - 08:44 PM
I'll measure cut width tomorrow, but I'm guessing 10", and the model # is 10-8. If that means anything.
#11 IamSherwood OFFLINE
  • 8,390 Thanks
Posted November 22, 2011 - 08:49 PM
Thank you Gibby. You understand.
Could I PM you my wifes email, and could you please explain it to her?:D
#12 olcowhand OFFLINE
  • 40,385 Thanks
  • 31,181 posts
Posted November 22, 2011 - 09:24 PM
Means nothing ........from what I've read they are 12" plows. Made 1947 thru 50.
#13 MH81 ONLINE
Posted November 22, 2011 - 09:37 PM
The Dearborn Plows were built for the Ferguson System units, Specifically the Ford 8-9-2 N tractors. They are nice plows and turn well, downside is none that I know of had trips for hitting rocks. If you were going fast & hit a rock... the plow would "Tweak"
#14 IamSherwood OFFLINE
  • 8,390 Thanks
Posted November 22, 2011 - 09:41 PM
Oh, hang on, I found a flashlight.
So, I measure at right angle from the plow tip, to the outer most edge?
#15 olcowhand OFFLINE
  • 40,385 Thanks
  • 31,181 posts
Posted November 22, 2011 - 09:44 PM
Yep, to outer most tip of cutting edge on the bottom.
