Tecumseh throttle backs off full throttle on its own
9 replies to this topic
#1 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted November 22, 2011 - 04:29 PM
My Ariens snowblower has a Tecumseh HH100 engine. Engine runs pretty good, except the throttle likes to back off on its own. It back off slowly to about 1/2 - 3/4 throttle. It didnt do this last year, and this year I took the carb apart for a cleaning.
What did I do?
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted November 22, 2011 - 05:20 PM
There is normally friction in the throttle control that holds it in position. If there is wear in the control or it is loose then it can slip back on you. I have an old tiller with a 3hp B&S that does the same thing. I just attached a spring to it that keeps it pulled WO. At some point I'll probably install a new control to solve the problem properly.
#3 olcowhand ONLINE
  • 41,205 Thanks
  • 31,433 posts
Posted November 22, 2011 - 05:33 PM
I have tightened them up by taking the throttle lever assembly off, then re-stake the rivet pin to tighten it up. Set the rivet head on an anvil or other heavy solid metal object, then use just a hammer or hammer/drift to peen the opposite end of the rivet down until you can feel it has snugged up the friction.
#4 DH1 ONLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted November 22, 2011 - 05:50 PM
:ditto: That's the way I do it too.
#5 MH81 OFFLINE
Posted November 22, 2011 - 05:58 PM
Another :ditto: here. Had a couple I've added some friction material to, but usually, just smack 'em one.
#6 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted November 22, 2011 - 07:35 PM
I have also used a pair of Vise-Grips to compress the rivet, sometimes easier to do than take it apart.
#7 olcowhand ONLINE
  • 41,205 Thanks
  • 31,433 posts
Posted November 22, 2011 - 08:25 PM
Yep, done that too....when it works. But the hammer is in the waiting if it needs more persuading!
#8 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted November 23, 2011 - 08:57 AM
Tightening the rivet is the best way to fix the problem, as others have mentioned.
If an engine is controlled by a throttle cable, another trick is to put a slight bend (mild kink) about mid-way in the cable. ...This adds friction, and will usually overcome the problem.
  • Bolens 1000 said thank you
#9 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted November 23, 2011 - 03:52 PM
Thanks everyone for the advice. Hopefully after Turkey day I'll tackle this issue
#10 olcowhand ONLINE
  • 41,205 Thanks
  • 31,433 posts
Posted November 23, 2011 - 07:57 PM
The only problem with this method is if the wire isn't the thicker style. If too much restriction the wire can wad up at the throttle lever. Had it happen before. If the heavy duty wire, this will work fine, but don't try it on the light duty cables.
